Originally posted by Joyce Keay Thank you for the very easy-to-understand explanation. I did a little test today at three different focal lengths and f-stops using the viewfinder and did another set of exposures using live view. This was with a measuring tape, my camera and my tripod using my 18-135mm lens but didn't see any appreciable focus problems. I did notice, though, that f/5.6 resulted in a clearer, bolder image than f4.5 or f4.0 at various focal lengths. Does that make sense? I've ordered a focus test kit from Amazon to test more scientifically. I also have the Pentax 55-300mm lens so will do the test with both lenses
Yes. The larger the aperture number (and thus smaller the actual aperture or 'hole' the lens makes for light to pass through) the sharper the image.. well to a degree. Once you get beyond f/11 it tends to soften again.
If you're testing AF adjustments, you'll want to test with the fastest aperture (smallest number) you have available for your lens. This will make the Depth of Field smaller (less of the scene will be in focus, just a sliver) which will aid in determining if your lens and camera combination are set properly.
In some cases 0 AF setting might be the correct setting, but it doesn't hurt to test and see (actually I'd recommend the test!).
