Originally posted by lushdimple11 Now, given you mentioned the AF and AE linkage, that's something I want to learn as well. What are the effects when AF links and not links to AE in different metering modes and in the outcome pics? Grateful if you could provide some further guidance.
More than a year later, here's an answer!
If the points are not linked, the camera will meter as follows:
- Spot metering: from a small area in the centre of the frame (about 5% I believe)
- Centre-weighted: What it says. Metering is weighted to the centre of the frame.
- Matrix or multi-segment: Metering is based on multiple zones from across the whole frame. (Higher-end cameras have more sophisticated metering using many more zones.)
If the AF and AE points are not linked, the AE metering takes no notice of whether the area metered is in focus or not.
As I understand it, if you link AE and AF points, it only works in matrix or multi-segment mode (at least in the K-3, but probably all the Pentax DSLRs):
Link AE and AF point - PentaxForums.com That is, in metering across the whole frame it gives more weight to areas in focus.
BTW, similar to other posters, I'd be happy with the photos you've shown, as a starting point for RAW processing. I tend to deliberately underexpose my images in bright conditions to avoid blown out highlights. The rest is easily fixed.
I'd say it's worth familiarizing yourself with one RAW converter. Then save settings you like for particular situations (e.g. backlit portraits, beach, flowers) as presets. They give you a starting point and make editing a lot quicker. Lightroom is the most popular but there are plenty of other commercial programs (I use DxO PhotoLab, which I really like) and free ones like RawTherapee or Darktable.
If you want to use jpg only, try exposure bracketing and keep the image with the exposure you like best.
