Originally posted by AnttiV Hi. Unfortunately my K30 is starting to show symptoms of the dreaded Aperture Problem. I have no spare money to ever fix it and will just need to live with it.
However as I've been so poor, the number of actual "new" lenses that I have is relatively small. I have a bunch of Pentax-M/M42 glass which obviously continue to work as before as they contain no automatics.
One of my K-50 bodies was starting to develop this issue. I looked around & figured that I'd try replacing the solenoid. I went ahead & ordered
this aperture solenoid plunger from eBay & not risk an unknown new replacement part from some random vendor. I went to Harbor Freight & picked up a
soldering iron & a
lead-free rosin core solder for about $8. I also had to get
this set of electrical screw drivers for about $9, since the ones I had were a bit too short & bulky to unscrew the aperture solenoid plunger screw. I opened up the camera by following
these instructions. The fix took me about 3 hours total 'cause of the soldering involved & going to Harbor Freight for those screwdrivers.
The soldering part was the hardest 'cause the replacement part & wires are really tiny. Be patient & work slowly.
Once you have the camera completely open, you have to remove the solenoid wires from the body.
By the way, the capacitor is more exposed on the K-30 than on the K-50, so be careful not to touch it. You'll have a shockingly good story to tell the grand kids. Hahaha! To remove the wires, you have to touch the point on the camera where they connect, but you have to be kind of careful. Make sure you move the other wires out of the way or else you could burn them. You gently pull on the wire end you are touching with the soldering iron at the same time & they slip right out once the weld gets hot.
Once you remove both wires from the camera body, you can unscrew & remove the solenoid & then carefully pull the wires off the green aperture plunger solenoid. Just grab them by the end closest to where they connect & gently pull them off. Don't really need to heat them. Then you peel off a very tiny bit of the rubber cover at each end. You can do that with your finger nails.
The easiest way to get the wires to reconnect to the solenoid & camera was to melt some core solder onto a piece of cardboard. You basically heat it up with the soldering iron & it starts to drip. You might have to heat up the drip a few times & keep dragging it around to get a smaller drips out of them. Then you grab the wire, heat up the drip again, & slide the wire into the drip. Do this for each side of the 2 wires. You'll need 4 drips of core solder.
Once you get some core solder on the wires, place the wire end over the solenoid & heat it up & the drip will melt onto the contact part. Just make sure you solder the correct wire to the correct location. When both wires are connected to the solenoid, screw it back in the body.
Now comes the slightly hardest part. Line up the wires to the body & first solder the wire closer to the plunger on the camera body. It's the pink one. Put the end where it should go & touch the core solder with the solder iron & it should melt right on. Do the purple one after.
You're pretty much done. The soldering might not look as clean as it did before the whole fix, but if you're careful & not messy, it'll work just fine. Reassemble the camera & as long as you don't drop any parts, bang up the parts, or accidentally overheat any parts, everything will be good.
So after $60 worth of parts & tools, plus about 3 hours labor, I say it was worth it. If you already have those screwdrivers, a soldering iron, & some solder core, the fix is only $40 plus your time. The fix should be permanent for the rest of the camera's life. It sucks that I had to fix it, but it is what it is. I doubt that Pentax/Ricoh is going to fix Hoya's cost cutting mistake. On the plus side, I've already shot about 800 shots & no issues whatsoever! And like usual,
"If you want something done right, you gotta do it yourself."
