Originally posted by Paul the Sunman
DFA* 70-200: Sharp as a tack, hand held, 1/60 - 1/200
I dont see shutter shock with any lens
handheld. The combination of damping action of the hands and the SR feature eliminate it it...at least for me.
I was refering to tripod use only
---------- Post added 09-07-2017 at 11:48 AM ----------
Originally posted by ffking
never do an edit with a sudden thought
So - using the 2 sec timer might help reduce mirror shock, which might also be an issue
From extensive testing with longer lenses my experience is that the shock in the 1/30-1/200 range, on a tripod, with a long lens, is caused almost exclusively by the shutter. Mirror up does not help.
What does eliminate it is to use LV with ES.
