Ahoi,
So i'm a bit daft with flash units and truly have only ever used them for fill lighting at best.
Looking for something with a bit more power, basically just want to buy once and not find myself wanting more power down the line. Helping out with a not for profit and will need a flash for the event, limited space inside and group photos will be impossible with faster primes (which is what I prefer to use). So figured time to bite the bullet and learn some more.
The thing i'm not really sure about is the whole 'zoom' aspect of the units. For example the Metz 64 is 24-200mm whilst the Pentax AF540 is only 24-85mm. Does that mean I can't use most of my 70-200mm length for example with the Pentax? Or does it simply mean the TTL will stop working and i'll need to adjust manually? Or does it mean something completely different?
And yes, I know both those models are probably overkill but basically I just want something I can use for whatever I want to do with them. Plenty of times I have thought i'd have loved to have a flash with me whilst using the 70-200 at the upper end of the range for a little fill lighting (to for example remove a shadow), so i'm sure I will find uses for it.
Appreciate any help/advice!
Oh and FWIW, camera gear in Canada is apparently stupidly expensive when you account for taxes... So looking at $440 for the Metz or ~$600 for the Pentax, before 15% tax (assuming you can even find stock).
