Hi, I have recently received a Takumar 35mm f2 from Japan. It was from a camera shop through eBay.
It was described as "Some dusts and some little dust specks. almost no cleaning marks, no fungus, no fogs. The lenses become yellowish (normal as 35mm f2). I rate this lens optical condition in Ex for the age. "
I looks really nice and I have used it and like it.
On inspection by holding it up to the light with the aperture open I can see hair line scratches. There are four, I tried a lens pen encase they could be removed but they can;t. Also there is a coating of haze.
It does not affect the images as far as I know.
There haze does not bother me as I guess it can be cleaned out at some point but is there any way of removing these scratches? I am guessing the term cleaning marks means fine scratches?
You cannot see them from the front! Only if you look through the rear element and use a flash light.
I could live with it but Just think if the optics are described as excellent by a camera shop they should be no scratches.
Here is the advert...
M42 Asahi Opt Co,Pentax Super-Takumar 35mm f2 w EX- | eBay
Any ideas?
I have just gone through my collection of Takumars now I know how to check them and am surprised how spotless they all are
Chris
Reason: Correction
