09-18-2017, 07:45 AM   #1
Pentax SMC DA 50mm f/1.8 DA on a K3
Hello everyone,
I have a K3 and have just purchased a Pentax SMC DA 50mm f/1.8 DA to try. The camera software has been updated to the current version. I tried this lens in AF mode and it wont focus or do anything. I have tried it in live view mode, which was suggested by other articles, and it still does not work. Works great in all manual mode. Anyone have any suggestions to try or could it be a dead lens?
Thank you.
09-18-2017, 08:38 AM   #2
KDD
Try to ALL RESET your K-3!! Because your K-3 is sleepy.
09-18-2017, 08:43 AM   #3
I'd try cleaning the electronic contacts for the camera body and the lens to see if that helps (probably a long shot but worth a try). Make sure you have the lens fully mounted. If you have another screw drive lens, try it to see if it is a camera issue. Make sure you haven't accidentally switched your camera's focus mode to manual. If no luck with all of these suggestions, I think you have a lens that was DOA and should be returned or replaced.
09-18-2017, 08:48 AM   #4
Larrymc's Avatar
Have you checked the camera with other lens? If they work correctly, then you may want to gently clean the lens contacts and also make sure the lens is seated properly. give this a try before anything related to a camera reset. If the lens was a used purchase it might be cheaper to send it back for a refund since the DA 50 f1.8 is a relatively inexpensive lens new.
LarryMc
09-18-2017, 05:06 PM   #5
I will try these suggestions. I will let everyone know how it goes. Thank you for the replies.
09-18-2017, 06:08 PM   #6
Hello. I tried all methods listed above with the reset being the last one. No luck at all. I attach the lens and input focal length still comes up. Guess its a bad lens. Thanks for everyone's help. Most appreciated. I will see what I need to do to return it.
Thanks to everyone again.
09-21-2017, 12:37 AM   #7
I would say the lens is defective. Make sure the camera is set on AF operation when you try it. Best to return the lens to exchange for another, since this lens has a good reputation for quality imaging.
50mm, 50mm f/1.8 da, camera, da, da 50mm f/1.8, f/1.8, k3, mode, pentax help, pentax smc da, photography, smc, smc da 50mm, troubleshooting
SMC Pentax A f1.4 50mm VS SMC Pentax M f1.4 50mm plunkstar Troubleshooting and Beginner Help 30 12-31-2015 09:04 AM
For Sale - Sold: Pentax SMC-M 50mm F2.0, SMC-DA 18-55mm F3.5-5.6 II, SMC-DA 18-55mm F3.5-5.6 davidreilly3207 Sold Items 3 12-26-2011 07:59 AM
For Sale - Sold: SMC Pentax-F 35-70mm F3.5-4.5;SMC Pentax-A 50mm F2;SMC Pentax-DA L 18-55mm F3. TATA Sold Items 14 06-17-2010 04:05 PM
For Sale - Sold: SMC 85mm f/2.2 Soft, SMC-M 50mm f/4 Macro, SMC-M 135 3.5, SMC-M 85mm 2, SMC-M jgmankos Sold Items 3 06-14-2010 06:48 PM
All times are GMT -7. The time now is 10:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
