09-27-2017, 03:33 AM   #1
Recommendations for SD card reader for '16 MacBook Pro for firmware file transfer?
Hi, I need an SD card reader in order to transfer firmware updates from my 2016 MacBook Pro to my Pentax K-70. There are several available on Amazon. Does anybody have a recommendation for a particular model and, conversely, any models to stay away from? Thanks.
09-27-2017, 03:43 AM   #2
photoptimist's Avatar
Why not just use a USB cable?
I don't think anything prevents you from attaching the camera directly to the computer, copying the firmware file to the top-level of the card, ejecting the camera (important!), turning off the camera, disconnecting it, and then starting the firmware loading process (power-on while holding a certain button if I remember correctly).
09-27-2017, 04:27 AM   #3
boriscleto's Avatar
Because the 2016 MacBook lacks USB 2/3 ports? It's USB-C only. So a USB-C hub is necessary. Or a simple USB-C to USB adapter...
https://www.amazon.com/Apple-USB-C-Adapter-Certified-Refurbished/dp/B06WLGFJ...SIN=B06WLGFJW8
09-27-2017, 07:23 PM   #4
QuoteOriginally posted by Joyce Keay Quote
The note regarding this firmware update reads as follows: Corrected – Unstable performance may rarely occur in firmware version 1.10.
(Updates from prior versions also included)
After watching the video on how to perform this firmware update (very scary) and reading the note above, I've decided to skip the whole thing. Thanks for your replies.
camera, card, firmware, macbook, macbook pro, pentax help, photography, reader, recommendations for sd, sd, sd card reader, troubleshooting
K3 , Bulb setting, and file transfer to SD WestCoastGuy Pentax K-3 & K-3 II 4 06-07-2014 02:06 PM
Difficulty transferring K-3 firmware update file to SD card FW Birds Pentax K-3 & K-3 II 8 12-31-2013 07:51 PM
Macbook Pro vs Macbook Air Mr_Canuck General Talk 6 04-15-2011 10:07 PM
MacBook or MacBook Pro fishy Photographic Technique 18 02-11-2008 07:09 PM
All times are GMT -7. The time now is 07:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
