10-02-2017, 07:59 PM   #1
A problem with the FluCardPro Pentax O-FC1 16 GB SD HC card
Hi!, I have got a Pentax K3 with a Flu Card Pro 16 GB SD Pentax O-FC1. It has been impossible to see in all my laptops, table and even in the smartphone the image that I want to capture. I can use the zoom In and out, see the saved pictures in the sd card and open the settings. But when I try to take a photo using the the LAN Pentax it always appears a message saying ¨the operation could not be completed correctly¨ Any solution to this problem?. Thanks you !
10-03-2017, 06:26 AM   #2
BigMackCam's Avatar
Which browsers are you using on your laptop and phone? I seem to remember this can happen if you don't use one of the specified compatible browsers...
10-04-2017, 03:32 AM   #3
There is an older post here about flu card issues. Make sure "image compensation" in the menu is unchecked. That worked for me.
10-04-2017, 08:37 AM   #4
It does not work with safari, Internet explorer or google.
10-04-2017, 10:10 AM   #5
BigMackCam's Avatar
QuoteOriginally posted by CJOS Quote
Do you have "Composition Adjustment" switched on in the camera, by any chance? I've read somewhere that it needs to be switched off...
Also (and I could be wrong here) I believe you need to shoot in RAW+ or JPEG with the JPEG being saved to the FluCard in slot 2.
Finally, try FireFox. I haven't used my FluCard for almost a year, but I seem to remember I had to run FireFox to get it working...
10-05-2017, 04:55 PM - 1 Like   #6
At last!!!! ¨composition Adjustment ¨was on. I did not know that.Thanks to both of you BigMackCam and Stihlmania. Really appreciated.
camera, card, flucardpro pentax o-fc1, gb, gb sd hc, o-fc1, o-fc1 16 gb, pentax, pentax help, photography, sd, troubleshooting
SD-HC Memory Card Comparison davidreilly3207 Pentax DSLR Discussion 6 12-01-2012 09:40 PM
Problème carte mémoire 4 GB SD HC Hélène Visitors' Center 2 09-08-2011 06:05 AM
Problem formatting PNY SD HC card in K10D Green_Manelishi Pentax Camera and Field Accessories 10 03-10-2009 06:47 PM
8 gb HC SD = 40 $ tomypreach Photographic Technique 9 12-22-2008 12:12 PM
All times are GMT -7. The time now is 10:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
