10-04-2017, 12:42 PM   #1
Pentax 18-135 WR doesn't look very sharp at infinity
Hello,
I have recently bought a Ks2 with a 18-135mm WR lens. This is a significant upgrade from my Kx+18-55mm. I took my new gears out last weekend and I took some pictures on a reasonably sunny day. I have the feeling that my pictures where not really sharp enough. Upgrading from 12Mp to 20Mp, I was hopping to see quite a lot more details. I have attached a couple of full size pictures and cropped versions around the centre. Any feedback would be very appreciated!
Anthony
PENTAX K-S2  Photo
PENTAX K-S2  Photo
PENTAX K-S2  Photo
PENTAX K-S2  Photo
10-04-2017, 01:17 PM   #2
There might be some camera shake in the first two, and the last isn't focused right. More MP should mean more detail, but it also makes the camera more sensitive to technique.
10-04-2017, 01:55 PM   #3
Thank you Adam for confirming my suspicions on the sharpness here.
I agree that shutter speed is relatively slow (1/100s) on the landscape shot but at 18mm focal I was not expecting that camera shake will be that noticeable.
Also here is another example with a faster shutter speed 1/250s at 40mm focal lens and it is still not very sharp either. Could that still be camera shake?
PENTAX K-S2  Photo
PENTAX K-S2  Photo
10-04-2017, 07:42 PM   #4
Kozlok's Avatar
Did you calibrate for back focus? Your lens may be focusing past infinity. Try again focusing using live view.
Are you smooth and steady? Do you smoothly press the shutter button? Try 5s delay on a support.
10-06-2017, 01:34 PM   #5
Thank you for the suggestion Kozlok. I have done some initial investigation last night at wide aperture and short focus distance. I didn't get any conclusive results. I need to try again during daylight but it seemed that the fine tune was not moving the focus point even when set at maximum correction. I'll try again this weekend. I suspect it could be the problem is there. One of my sharpest photos so far is a selfie taken with one hand. This could be because this was taken with live view so didn't have any back focusing issue.
10-06-2017, 03:53 PM   #6
I had my best results adjusting the front/back focus on my 18-135 lens by focusing on a distant object with good contrast in good light. I was not able achieve good results using a close object. Hope that helps.
camera, pentax 18-135 wr, pentax help, photography, pictures, troubleshooting, wr
Is Pentax 100mm Macro as sharp focused at infinity as up close? *Rich Pentax SLR Lens Discussion 28 11-20-2016 03:03 AM
Nature Very Pretty, Very Yellow, Very Big Flower. Tonytee Post Your Photos! 14 06-12-2016 03:45 AM
For Sale - Sold: Selling K50 + 18-55 WR kit lens + 18-135 WR lens Moropo Sold Items 7 02-10-2016 03:23 PM
For Sale - Sold: Pentax DA 18-55 WR, DAL 55-300, and DA 18-135 WR lenses Elliot Sold Items 4 11-07-2013 02:46 AM
All times are GMT -7. The time now is 07:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
