10-08-2017, 08:33 AM   #16
I typically used either a 28mm or 35mm on crop body when I shot car shows. I started out with the Sigma 10-20, but I didn’t like the perspective distortion it created even at 20.
10-08-2017, 10:09 AM   #17
Just1MoreDave's Avatar
QuoteOriginally posted by pres589 Quote
Options not yet mentioned, all primes, the Samyang 10mm, 14mm, and 16mm primes. All fast, have been around for a few years at least so used copies are out there, and all offer a wide aperture for low-light and depth of field control. All are manual focus, so be aware.
My brother uses the Samyang 10mm on a K-r. He reports focusing is not that hard. He knows by now to set the focus ring at a particular distance for the typical shot of the car filling the frame. That works unless he goes from a Pierce Arrow to a Lotus Elan. Because it's so wide and he doesn't have anything else between that and the 18-55, it's easy to pick out his 10mm shots.
10-08-2017, 11:38 AM   #18
Jome's Avatar
Hello,
I had exactly the same question few months ago and I have had good advices by the other members and finally I got there with my HD 15ltd (5% of pictures taken), the HD 20-40 ltd (85% of pictures taken) and the FA*85(10%).
It was my first time in an indoor car show and you can check some of the results in my gallery (Hope it helps).
Problem I encountered: Some colors don't help the AF, and I had issue wit some fast rotating cars on their stand.
Try also to take pictures (if allowed) at your local car seller.
Good luck.
Kind regards.
J.
10-08-2017, 02:53 PM   #19
I have a DA 16-45 lens, a DA* 16-50 lens and the Sigma 10-20 lens. For our purposes, I would suggest the Sigma as I think you would need all the width you could get when at a car show. You just cannot get far enough away without distractions to the shot with anything narrower. Good luck.
camera, car, lens, lens size, pentax help, photography, troubleshooting
Getting permission to photograph a car at a car show Black Magic Troubleshooting and Beginner Help 16 07-08-2019 07:17 PM
what brand wifi card would you recommend for my K1 ? is there any maz size for it ? brando Pentax Camera and Field Accessories 4 08-21-2017 04:50 PM
Get car show lens on a tight budget or use owned one? fullmental Pentax SLR Lens Discussion 40 02-24-2016 10:34 AM
Which one would you recommend? (SH Pentax) ftpaddict Pentax Film SLR Discussion 15 01-05-2008 03:04 PM
Car Show "abstracts" Greenwich Show mutley Post Your Photos! 16 06-22-2007 10:59 AM
All times are GMT -7. The time now is 08:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
