Originally posted by Stratus106 Thank you so much for the replies! It did turn on holding the Menu button (Thank you). It does not stay on long enough to update the Firmware so will try lithium batteries and/or a power supply. Thanks for the support.
It is good that you don't try to update because it most likely is a battery problem.
First read this one:
Battery type AA/NiMH/Eneloop in K-x, K-r, K30 K50, K500 as well as *ist/K100/200/2000 - PentaxForums.com
because here the most common problem with batteries is explained.
So what you want is a good set of NEW (!!!) Eneloop rechargeable AA batteries
+ a good charger such as the Panasonic BQ-CC65
or even better this one:
https://www.amazon.com/BT-C2400-Battery-Analyzer-rechargeable-batteries/dp/B00MYQ8IYS
The K-x won't take a external powersupply! No socket for it.
The method of connecting a PS via the inner contacts can work but you need to know exactly where to hook those crocodile clips.
Wrong contact would not be on your wishlist. Nor as @LensBeginner wrote a breakdown during flashing the firmware, that would be final exodus.
VERY OFTEN it is just contacts! Together with weak batteries I'd say 95% of all cases and thus to be resolved.
Same for all other Pentax bodies using AA's!
Check those contacts. Make sure the inner contacts are clean and have no green stuff remaining from defunct batteries with leaked!
Same for the contacts on the door. Bend these a bit more so they can really give a strong touch to the AA's.
And stay far away of such sledgehammer methods:
Originally posted by cublai I dig out this old camera and it won't turn on whatsoever.
Eventually I built a battery pack of 6 AA battery and tie it to the battery chamber of the camera with a rubber band.
The camera just needs 4 batteries by design but I guess it is simply not enough. After I forced 6 batteries on it, everything works fine.
It is really stupid design.
I agree, this design of yours forcing 6 x AA's to run the K-x is indeed really stupid.
Mongolian invasive method?
