11-11-2017, 12:08 PM   #1
Pentax k2000 Memory Problem
I got my Pentax a year ago and have had no problems until recently; my photos will not save on as card in format of jpeg/raw etc. Photos I try to take will at first say 'camera cannot display image' and then disappear altogether! What should I do ( I am fairly bew to photography), is it worth getting a new card or should I change the format or re-format the one I have? Thanks guys
11-11-2017, 01:04 PM   #2
First try formatting the card in camera, and if that doesn't help, format it on your PC. If that doesn't help, try a different card (buy one with the UHS-I designation, I recommend sandisk).
SanDisk 32GB Extreme PRO SDHC UHS-I Memory SDSDXXG-032G-GN4IN
If that doesn't help then there's likely a bigger issue with the camera. If you're looking to replace it, the K-S2 or K-70 would be a fine choice.
11-11-2017, 05:47 PM   #3
heinamj's Avatar
I had a K2000 as my first DSLR and I got a message like that when I first tried to use it with a basic low grade card... Switched to a SanDisk ultra card and had problems after that. Nice little camera that gave me back my love of photography...
11-11-2017, 10:00 PM   #4
Thanks! I will try formatting the card!
11-11-2017, 10:01 PM   #5
QuoteOriginally posted by heinamj Quote
Ok thanks so much!
11-26-2017, 08:35 PM   #6
I've had my K2000 for a little over 5 years now, and I just experienced the same problem. I was out getting ready to shoot the Christmas lights downtown and forgot my current memory card was full (32GB card). I had a spare (a 16GB card), so I switched them out. I was able to take 3-4 photos, and then it stopped saving my images and the previous ones disappeared.
I tried formatting the card with my camera and then with the PC-neither worked for me. I inserted my old memory card (after I had backed it up) and it now says memory card error. However, I took it out immediately and checked it using my PC-the content is still there, thankfully.
I had just recently switched from shooting in jpeg to shooting in raw. I didn't switch the format from jpeg to raw until after I had inserted the 32GB card and switched on my camera. I still had my camera set to raw when I put the new 16GB card-and that's when my problems started. On a hunch-my stepfather suggested switching back to jpeg, then reinserting the 16GB card and reformatting it in the camera-it actually worked! I took a test shot in jpeg, switched to raw and took another test shot. So far so good...
I hope you were able to get your memory card to work, too!
card, format, pentax, pentax k2000 memory, photos
K-r memory card problem keithg59 Troubleshooting and Beginner Help 7 06-11-2017 11:33 PM
SanDisk memory card works on PC but says 'memory card error' in K-S2 kudzx Pentax K-S1 & K-S2 9 02-15-2017 09:03 AM
just purchased and fired up.. problem with memory card teleioo2002 Troubleshooting and Beginner Help 13 09-21-2016 10:17 PM
Pentax K2000 flash problem...I think 68mpolo Troubleshooting and Beginner Help 5 09-22-2009 09:11 AM
Largest memory card for K2000 papergypsy Pentax DSLR Discussion 3 05-22-2009 07:34 AM
All times are GMT -7. The time now is 03:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
