Originally posted by Kombivan No thats not it as a = aperture, does the flash read the aperture when in aperture priorty and using the aperture ring?
The flash won't know the aperture unless the aperture ring is set to "A", and consequently P-TTL automation will not work if you set the aperture using the ring.
Originally posted by Kombivan The reason this is important to me is for 20 years I've been taking photos via Aperture priorty since I got a digital camera 15 years ago the flash has always been over exposed until recently I started using program mode which fixed my problem but I want to get back to aperture priority when I understand this over exposing when in Av when using the flash and ring aperture for setting the aperture. If I have to set the aperture in the camera body I will have to get a different camera as the K-m doesn't have the setting on the top of the camera but in the lcd viewer which would be a pain to change all the time.
Here's what you need to do to accomplish what you're after:
1. Set the aperture ring to "A".
2. Set the mode dial on top of the camera to Av
3. Select the aperture you want using the e-dial on the camera
4. Fire away happily
Again,
never turn the aperture ring away from "A" and you should be ok
On the K-m, you should be able to get all the status info to appear on the rear LCD, since there is no top screen. Try pressing the info button.
PentaxForums.com Webmaster (
Site Usage Guide |
Site Help |
My Photography)
PentaxForums.com server and development costs are user-supported. You can help cover these costs by
donating or purchasing one of our
Pentax eBooks. Or, buy your photo gear from our affiliates,
Adorama,
B&H Photo,
KEH, or
Topaz Labs, and get
FREE Marketplace access - click here to see how! Trusted Pentax retailers:
