11-18-2017, 12:37 PM   #1
Battery life Pentax KP
About 3 months ago I told about issues with af and battery life.The camera was sent to the dealer and after 6 weeks where the camera had been on a trip from Denmark to Holland I received a new camera which I am testing now for af accuracy. The problem with low battery life does still exist. I get in average 160 photos before the battery is empty. Is that what I can expect or is it something worse? I have 3 original batteries and 1 third party, there is no difference. The batteries are ok with K30.
11-18-2017, 12:46 PM   #2
MarkJerling's Avatar
Are you using the viewfinder, or LiveView?
11-18-2017, 12:47 PM   #3
viewfinder and no flaSH
11-18-2017, 12:53 PM   #4
QuoteOriginally posted by niels hansen Quote
Yeah that's definitely not normal. What lens are you using?
11-18-2017, 01:13 PM   #5
Ole
Ole's Avatar
When we tested the KP we got about 370-380 shots, the test is here.
Have you extended the time for when the camera goes into the power saving stand-by mode by any chance?
11-18-2017, 01:28 PM   #6
pentax 35 2,4 pentax 50 mm 1,8 sigma 70 mm 2,8 macro I always close the camera after taking a picture.the battery delivered with the Kp was made in 201504... the voltage on all the batteries when koaded is 8,4 volt
11-18-2017, 02:03 PM   #7
Just in case it may be relevant, I remove the battery from camera(s) when not using, and also usually charge up on the day prior to shooting to ensure charge.
---------- Post added 11-18-17 at 04:11 PM ----------
I read on dpreview that the number of shots expected was 390 using OV (optical viewfinder).
If you are possibly shooting JPEG and RAW (simultaneously), then that may be a factor, or if you are shooting RAW vs. JPEG, the JPEG being the smaller file.
Just ideas.
11-18-2017, 05:20 PM   #8
MJKoski's Avatar
I made a thread about this on KP forum. I have exact same problem but it is worse I think. Probably the capacity of default battery is so low that voltage drops a bit too much when temps drop to 0C and all I get is a handful of 30 second exposures before camera shuts down.
Sony A7R2 or R1 had the exact same capacity for the NP-FW50 battery but it worked nicely down to -10C before things started go wrong.
Does not matter if I use live view or not.
11-18-2017, 05:30 PM   #9
I considered to buy KP for myself for incoming Xmas. You have seriously distracted me as I like a lot making photos during winter time... :-(
Either the some batteries batch is affected with low capacity in low temperature issue or the KP is a jewellery only, useless below zero centigrade...
11-18-2017, 06:07 PM   #10
The D-Li109 battery is used in the KP. Its specs list 1050.00 mAh and 7.4VDC
The Pentax D-LI90(E) battery is used in K-20D, K-5 series, K-3 series, K-1, and 645Z cameras for example. Its specs list 7.2VDC and 1860mAh.
If power is what a user needs, the camera bodies that use the D-Li90 may serve the purpose. I use only Pentax batteries.
11-18-2017, 11:56 PM   #11
I always only use RAW( DNG)
11-19-2017, 01:39 AM   #12
I have found the CIPA test procedure and will try to use it - Maybe the problem is temperature related
The manual uses 23 celcius when they mesure the capacity, most of my pictures are taken outdoors between 5 and 10 celcius. I come back later
11-19-2017, 01:44 AM   #13
I would definitely get under 200 shots shooting purely in raw with my KS-2 which uses the same battery. This is for shooting birds in flight. Your figure in raw is not dramatically different from mine for that battery type. I don't think you have a flaw with your camera. Neither of these cameras have particularly long battery durations. I just count on spare batteries. Perhaps you mighty consider getting the battery grip for the KP.
11-19-2017, 04:35 AM   #14
It brings to my mind behavior of OM-D E-M10 in low temperatures - a few dozen of photographs and the battery is dead. If KP works in this manner as well, then - thank you Mr Pentax :-P
11-19-2017, 05:14 AM   #15
I don't have a KP but apparently it has wi-fi connectivity - is that a factor in your battery's life?
Philip
af, batteries, battery, camera, charge, pentax help, photography, troubleshooting
comprar una KP o pasarme al formato compreto (Buy a KP or switch to the full format)? mariovidal Pentax KP 5 06-29-2018 05:45 AM
Why Pentax KP? Para que la Pentax KP? ZeaFoto Pentax KP 16 06-14-2018 08:53 AM
Imagine life if all the legacy FA* come back to life in D-FA* form... shardulm Pentax SLR Lens Discussion 33 08-15-2016 03:09 PM
Nature A bee's life is a busy life. charliezap Post Your Photos! 4 08-03-2013 02:22 PM
Shutter Life v.s. Half-Press AF Life? shang Pentax K-5 & K-5 II 16 02-06-2011 12:41 AM
All times are GMT -7. The time now is 09:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
