If you shoot raw the dynamic range setting doesn’t matter much. If you are a JPEG shooter the DR settings can be helpful. Auto works well but you achieve better in camera JPEGs with tweaking the highlight and shadow settings.
For the program settings it is also very situational. If you will be rapidly switching between action, portraits, landscape, the auto can be useful. For most situations I use the setting appropriate for the shot itself. Many aperture priority or manual shooters will not worry about program line since they set everything manually. I am a RAW+ hyperprogram shooter and change settings with every shot so I usually leave the program line on normal on my K-3 for ~80 % of shots. However, when I shoot horse shows, I will switch to the action program line to make things easier.
