Originally posted by armel Hello,
On the joined photos, we can see the classical flange (2cm?) of a PK mount (Carl Zeiss Jena 70-210mm). I recently bought a Vivitar Japan 70-210mm with a so-called PK mount (that's what the rear cap says). The flange is 3-4cm long. In both cases, there is a mobile piece, this one being not exactly the same size in both cases.
1-Is there a ring allowing this pseudo PK zoom to be considered as a true PK mount ?
2-If not, a friend suggested to "reduce" the size of the flange : unscrew the black rear part to separate it from zoom, put it in a convenient place to reduce it (dremel, file...). I confess the 1st solution would be better.
3-Does someone know the name of a camera which accepts that kind of pseudo K-mount ?(the thread suggests a Konica mount, but which Konica camera ?)
thanks,
armel
Yes, this is a K-mount lens (PKA) with the long "Vivitar flange". The problem with the long flange is that it hits the PZ/SDM contacts and won't mount properly on a KAF
2 mount. It can usually be removed without any problems. It can be reduced in size with a dremel as well.
The lens in your original post is a Konica mount, the focal flange distance of the AR mount is much shorter than K-mount so an adapter need to be optically corrected. The 70-210 is PKA mount, but it should be checked for the "Ricoh pin".
