11-23-2017, 04:52 AM   #1
SMC Pentax-FA 50mm Macro Clamp knob/action
Hi, I see there has already been previous discussion on this topic, so my apologies if I have missed something.
I have recently bought an otherwise apparently excellent copy of this lens from Japan on eBay. My question concerns the action of the CLAMP knob. Mine rests fairly firmly/tight at the 'off' position. But once out of 'off' it rotates quite freely/loosely, with no equivalent tightness when arriving at the 'on' position (which would then assist in holding it there). As far as its clamping action goes, in MF there is indeed a discernible increase of friction on the focus ring, albeit not that great but it works. I can see that it would assist in its intended purpose, so it at least appears to be effective. Looking at some of the earliest reviews on PF for this lens, there is a suggestion that the CLAMP knob action on my lens may actually be factory-perfect. Could anyone please confirm or otherwise? Many thanks, mike (UK)
11-23-2017, 05:29 AM   #2
The knob on mine feels that way too. Much too loose after you move it away from the off position.
Good thing they fixed this design issue in the D FA version.
11-23-2017, 07:31 AM   #3
Mine too. Very loose in any position other than the off position. On the other hand, this feature is only really intended for use on a copy stand and it works well for that. The “looseness” is not an issue for normal autofocus use. I do wish there was a focus limiter on the lens.
11-23-2017, 09:44 AM   #4
UncleVanya's Avatar
QuoteOriginally posted by Pentax Syntax Quote
The focus limiter is what I miss most from my F 100 Macro. I have the D FA 100 WR and like it but I do miss that feature.
11-23-2017, 11:27 AM   #5
I don´t have the FA 50 but the FA 100 2,8 , since more than 15 years , and the behaviour of the clamp of my lens is exactly what you describe , i.e. resting firmly at "on" and "off" position and loose at the rest of the way. Howver, It does the job increasing the friction when the focusing ring rotates , avoiding shifting in focus due to the own weight of the lens , which is useful mainly for close-up pointing down shots .
11-24-2017, 01:37 AM   #6
Thanks guys, for these responses.
As I suspected, it appears that the state of my lens is as most others'. So I'm concluding that the FA 50mm Macro lens was actually made that way originally, and the CLAMP knob looseness is therefore not a result of wear-&-tear on my particular copy.
10-16-2020, 07:29 AM   #7
Dear PF members, does anyone know if the clamp in its "ON" position switches off AutoFocus? I know from forum research that in the DFA, the OFF position does, and makes catch-in-focus (CIF) possible. Does this work the same way in this FA-50mm macro, I aim at: is CIF possible with this lens (other than the lens unlock knob trick)?
10-17-2020, 03:37 PM   #8
I don´t have the FA 50 macro but the FA 100 macro , and with the clamp at the "on" position doesn´t switches off the AF .
10-18-2020, 02:40 PM   #9
jopenmx, thanks for your reply. A step closer to an aswer. Big chance the FA50 will act the same as the FA100.
action, camera, clamp, knob, lens, pentax help, pentax-fa 50mm macro, photography, position, smc pentax-fa 50mm, troubleshooting
Pentax-FA 50 2.8 Macro - function of the clamp switch? npc Pentax SLR Lens Discussion 2 03-15-2015 12:32 PM
SMC DFA 100f2.8 macro clamp k9lover Pentax SLR Lens Discussion 3 03-03-2014 03:47 PM
For Sale - Sold: Pentax 50mm Galore. **FA 50mm 1.7, DA 50mm 1.8 & FA 50mm 2.8 Macro jjdgti Sold Items 9 08-05-2013 04:41 PM
FA 1:2.8 100mm MACRO clamp question. aoeu Pentax SLR Lens Discussion 8 04-29-2013 05:32 AM
For Sale - Sold: SMC 85mm f/2.2 Soft, SMC-M 50mm f/4 Macro, SMC-M 135 3.5, SMC-M 85mm 2, SMC-M jgmankos Sold Items 3 06-14-2010 06:48 PM
All times are GMT -7. The time now is 11:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
