11-27-2017, 04:00 PM   #1
ZombieArmy's Avatar
Tight fitting Pentax-M 50mm f 1.7?
Hi. I just got a Pentax M 50mm 1.7 on ebay. The lens is in immaculate condition but it seems to take a lot of force to get it on my k-01. To the point where I think it scuffed the mount a little bit.
This doesn't happen with my 200mm which is also an M lens, what could be the cause?
11-27-2017, 04:04 PM   #2
photoptimist's Avatar
Maybe a warped mount ring or bent bayonet tabs?
I'd sight along the ring and tabs carefully to see if you can find the offending bend.
A wee bit'o filing (with ALL lens opening covered in masking tape) might reduce the tightness if you can identify the source.
11-27-2017, 04:09 PM   #3
twilhelm's Avatar
Sounds like it was dropped on the mount. Do a close inspection side be side comparison with your 200. You’ll find the problem spot.
11-27-2017, 04:09 PM   #4
Not a Number's Avatar
The location of the scuff marks should provide a clue where a possible problem could be.
It may just be the luck of the draw - the mount on the lens as at towards the extreme in one direction of the specified tolerance and the mount in the other direction. Both are still within specifications but combined things work out to being stiff or tight.
11-27-2017, 04:35 PM   #5
ZombieArmy's Avatar
I can not perceive any warping on the mount. The pentax 200mm will go on and turn with no effort, while when i put the 50mm on it will not move at all with the same amount of force.
11-27-2017, 04:44 PM   #6
pschlute's Avatar
The M50 mm are cheap enough on ebay. Get another and sell yours for parts
11-27-2017, 04:50 PM   #7
ZombieArmy's Avatar
Sorry but we're not all in a situation where we can throw away money.
11-27-2017, 04:53 PM - 1 Like   #8
pschlute's Avatar
QuoteOriginally posted by ZombieArmy Quote
Well then throw away the lens. Or would you prefer to keep damaging the camera mount?
11-27-2017, 04:54 PM   #9
ZombieArmy's Avatar
You could leave my thread.
11-27-2017, 04:57 PM   #10
Honestly, I think he's giving you good advice. The camera is worth more than the lens.
11-27-2017, 04:59 PM   #11
ZombieArmy's Avatar
I thought it was common sense to stop using a lens that requires 6x the force to mount onto the camera. The thread is for causes and possible solutions, not to tell me to call it all a loss "because it doesn't cost much".
11-27-2017, 05:24 PM   #12
twilhelm's Avatar
Unfortunately that is part of the risk of ebay and buying old equipment. People will put things on for sale which look good but have a defect. I've lost a few and I've won a few. I bought a Sigma 28 which looked new, but was so badly de-centered it was not usable. Then I had a guy ask if I wanted a horrible looking lens in K mount with a bent filter ring and he threw it in for free. I got one of my favorite lenses, a K 55 1.8 which looks terrible, but has perfect glass.
11-27-2017, 05:26 PM   #13
jatrax's Avatar
You already got the most probable cause, the mount is bent. Carefully examine where it is rubbing and you should find the issue. I sorta agree with the other poster about tossing it out, an M 50 f/1.7 should be what $25-$30? Not worth damaging your camera. But in your case you bought it on ebay so tell the seller it is defective and you want a return.
If you don't like those options then get out a file as @photoptimist says.
Or just keep using it and scratch up your camera mount. Leaving this thread now.............
11-27-2017, 05:29 PM   #14
Otis Memorial Pentaxian
It should mount easy and smooth unless the lens mount was poorly machined or has been damaged. As noted above, are there any signs of unusual wear, scratches, or damage to the mount tangs or mount face? Is the aperture actuator properly aligned and fully operable with a flick of the finger with no roughness or hesitation? (A bent/misaligned actuator is a dangerous thing.)
You are right to be exercising full caution with the lens on your camera. A defective Russian fisheye permanently damaged the aperture actuator of one of my film bodies. You may want to be talking to the seller.
11-27-2017, 05:34 PM   #15
ZombieArmy's Avatar
That's the thing. When compared to my other M lens it looks no different at all. It's incredibly strange.
Yeah it works incredibly smoothly. The lens seems to snag immediately on the body when putting it on, like it never lines up, but no matter how I look at it I can't seem to tell where the problem is.
50mm, camera, lens, pentax help, pentax-m 50mm, photography, troubleshooting
Fungus and fitting Pentax M and Pentax-A lenses on Pentax MZ S body? RustyT Film SLRs and Compact Film Cameras 5 02-16-2018 05:43 AM
Tight fitting M42 adapter - suggestions? 6BQ5 Pentax DSLR Discussion 5 05-26-2017 07:20 PM
Pentax 70-200 not fitting on tripod kellys Troubleshooting and Beginner Help 8 01-28-2017 11:44 AM
Fitting a SMC Takumar 50mm to a K-r jamesd256 Troubleshooting and Beginner Help 6 02-01-2012 09:46 PM
Help with fitting 6x7 lens to K fitting Mick C Pentax Medium Format 5 02-04-2011 02:37 PM
All times are GMT -7. The time now is 04:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
