Hi All,
I have recently picked up a Pentax ME Super for $20. I knew the camera wasn't fully functional when i bought it, but it came with a flash and 28mm pentax lens in really good condition so bought it anyway as I can use the lens on my k1000.
I've been playing around with the camera, initially the lens was stuck up and i gently pulled the shutter curtain to fix this as suggested by many on this forum.
The shutter however would not fire and I was able to continuously wind without firing.
Since then I have gotten to the point where the shutter will fire every few winds. Often it will make a clicking noise or a spring noise on the return after a wind and then the next wind will work and the shutter will fire.
I removed the plate on the bottom of the camera and found that the wind lock does not engage on every wind but every 2-4, depending.
Sometimes I can get it to engage on constitutive winds if I am lucky.
Image 1 shows the wind lock not engaged despite winding.
Image 2 shows the wind lock engaged after several attempts
Does anybody know how to fix this issue? Is it simple enough to fix myself?
Will it keep reocuring?
Cheers Sam
