12-14-2017, 01:34 PM   #1
What are the best settings for speed in continuous shooting K-5.
Beginner help and Troubleshooting please.
I'd like to know, step by step, how to switch Off anything that slows down continuous shooting mode, and best settings to use for this, plus saving them in User mode please.
Sometimes 'fast shooting doesn't happen in my K-5 for some reason something is holding it back and I get occasional camera freeze then have to take out the battery and replace it to fix this.
I have read something by TER-OR posted 06-05-2013, (thank you TER-OR) and now need to know how to find where I switch off Lens correction etc.
I think I have saved the basics in a User mode but does this work with different lenses? eg. one lens does not show F stop and one burst shoot I did just never appeared in my playback.
I used TAV mode.
I do need advice step. by. step. please to keep me from getting lost in the manual. I'm spending my life in there.
All the best Pentax lovers,
from
AnnieK5 on Mornington Peninsula down under.
12-14-2017, 01:46 PM - 1 Like   #2
mcgregni's Avatar
The easiest way to access these settings is from the Control Panel ....press the Info button when the Status Screen is displayed. You use the 4-Way controller to move around and the OK button to select the setting to change.
You should switch off Distortion and Abberation corrections.
12-14-2017, 01:58 PM - 1 Like   #3
Just1MoreDave's Avatar
The card should be fast but that's in 5 years ago terms. Probably something labeled class 10 is fine. Press the Info button until you get a screen with the time and date at the bottom. That has lots of the settings you need. You can turn everything in the middle 8 boxes off, Highlight Correction to HDR. JPEG will be faster because the camera should be able to write the files to the card faster. I think the K5 is supposed to be able to continuously shoot JPEGs in high speed until the card is full. You can switch to manual focus so the camera doesn't have to think about AF. That's about it.
12-14-2017, 03:44 PM - 1 Like   #4
clackers's Avatar
QuoteOriginally posted by AnnieK5 Quote
I used TAV mode.
from
Hi Annie,
The manual's meant to be a reference, not to learn from ... I think you'll find this much more friendly!
Pentax K-5 e-book
Cheers,
Ian
12-14-2017, 06:57 PM - 1 Like   #5
Make sure you disable distortion corrections - that's what adds the most processing time and kills your framerate. Everything else is negligible in comparison.
You'll get the most frames in JPEG mode, but the buffer size in raw is also workable. I wouldn't recommend raw+ simply due to the limited buffer size.
12-15-2017, 12:56 PM   #6
QuoteOriginally posted by mcgregni Quote
Great thanks, downloaded to read.
---------- Post added 12-15-17 at 12:57 PM ----------
Okay and thank you.
buffer, button, camera, corrections, distortion, info button, lens, mode, pentax help, photography, settings, size, status screen, step, switch, troubleshooting, user
Best autofocus mode to use with high-speed continuous shooting? Aerlind Pentax K-3 & K-3 II 14 04-29-2017 02:03 PM
Shooting speed slower in continuous focus mode? leonardotmnt Pentax DSLR Discussion 10 09-02-2016 07:42 AM
Pentax K-500 continuous shooting speed dvir Pentax K-30 & K-50 5 03-16-2014 02:13 PM
K3. AF working and continuous shooting speed ArsenAl Pentax K-3 & K-3 II 2 11-13-2013 11:22 PM
Shutter speed changes even with AE-L during continuous shooting. geomez Pentax K-01 2 05-31-2013 01:19 PM
All times are GMT -7. The time now is 09:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
