Originally posted by stevebrot What I am seeing in the video is something called focus breathing. Magnification with external focus primes increases as the lens is focused far-to-near. FOV also decreases resulting in a change of the of relative position of points within the frame. There is also a small change of point-of-view due to extension. I also noticed some camera movement.
Originally posted by Ontarian50 However, looking at the OP's video, I can't determine if we're talking about focus breathing as he focuses closer, or the little sideways jiggle as the focusing is moved.
Is it just the tripod shifting slightly as the lens is touched? Or is the camera super solidly mounted, and the lens does indeed have some slop in its focusing mount, and needs re-greasing to snug it back up again?
Originally posted by stevebrot Any of the above might be contributing, though my vote is camera motion during the focus pull.
Originally posted by stevebrot I was thinking that maybe a direct comparison with the OP's DA 50/1.8 might help sort things out as well.
Thanks for the replies.
I don't mind the focus breathing as you guys have mentioned -- it's the up/down/left/right movement of the frame(?) that bothers me. There should not be any camera movement, as I have my K-5 on a decent tripod and have confirmed that all knobs are tight. As Steve advised, I have uploaded two videos for a comparison between my A 50/2 and DA 50/1.8, recorded within minutes of each other with the same camera and tripod positioning. I tried to adjust focus quickly to make the effect more obvious in both videos.
First, the A 50/2:
Then, the DA 50/1.8:
As seen in those two videos, the frame movement with the A 50/2 is a lot worse than the DA 50/1.8 (if there is any).
