Originally posted by clickclick Just curious as trying to learn more, what is it about internal focus that would cause this?
Internal focusing systems in lenses are utilized to keep lenses compact and reduce the number of externally moving parts. They are designed with stationary* front and rear cells with a focusing group that moves internally and non-linearly with focus distance**. The focusing group is
typically in the optical center of a lens, though there are cases where the focusing group can be situated close to the front** or rear cell. The non-linear motion of the focusing group gives lens designers freedom to compensate for aberrations over a wider range of focus distances. Another advantage internal focus brings is the AF drive module doesn't have to move the entire optical assembly to focus: instead it only has to move the focusing group which, even in lenses with very wide apertures will have considerably less weight and mass, so AF gains considerable speed and responsiveness.
The downside is that internal focus designs can often exacerbate focus breathing and this is particularly noticeable in the case of macro primes and lenses with a zoom ratio approaching or greater than 1:3. Also Internal focusing can alter the effective aperture of the lens itself due to loss of focal length at close focus distances.
Originally posted by stevebrot This is a very poor explanation of what actually happens, but I could not find the reference I was looking for that explains internal focus in terms of primary planes.
There is a lot of reference material out there but a lot of it seems to have trouble making the distinction between floating elements and internal focusing.
*Though in some cases IF lenses do utilize forward and rear extension the degree of extension is far less than any equivalent non IF lens could manage and maintain the same functional purpose.
**As opposed to common block focus lenses which move in a linear fashion. Though to further complicate things: there are lenses that feature floating lens elements which can have individual lens elements that can be completely stationary, or move in contrary motion to the primary optical groups - and these lenses themselves may have internal focus groups in them as well.
*** this is a very common trend with retrofocus wide angle lenses which are already a headache to design.
