12-17-2017, 05:20 PM   #1
K-3 II with HD PENTAX-DA 55-300 ED PLM WR RE
Hi,
Iīm a beginner user, so it can be a basic mistake...
Iīve a Pentax K-3 II and 3 lens: 1) SMC PENTAX-DA 40mm XS; 2) HD PENTAX-DA 18-50 mm DC WR RE; and 3) HD PENTAX-DA 55-300mm ED PLM WR RE.
The first and second lens works well, but I canīt shot with HD PENTAX-DA 55-300mm.
I canīt change focus with MF mode and nothing happens with AF mode (camera donīt focus and donīt shot).
I updated firmware to V1.10 and reset configurations, but it still not working...
Any idea?
Tks
12-17-2017, 05:55 PM   #2
Seeker of Knowledge
aslyfox's Avatar
I don't have that lens - HD PENTAX-DA 55-300mm ED PLM WR RE.
have you reviewed this material
in depth review for the lens
HD Pentax-DA 55-300mm F4.5-6.3 PLM WR RE Review - Introduction | PentaxForums.com Reviews
HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE Reviews - DA Zoom Lenses - Pentax Lens Reviews & Lens Database
and the info for the camera body and operating manual
https://www.pentaxforums.com/reviews/pentax-k-3-ii-review/introduction.html?src=lrdb
http://www.ricoh-imaging.co.jp/english/support/man-pdf/k-3-2.pdf
you might want to post your questions to these threads to see if any of those posters have an idea
FA 100-300 vs Pentax 55-300 PLM - PentaxForums.com
https://www.pentaxforums.com/forums/130-lens-sample-photo-archive/352727-hd-...plm-wr-re.html
12-17-2017, 07:40 PM   #3
RE means the lens is retractable; to extend it and shoot, you need to press a button on the lens body and turn.
I assume you have done that before trying to shoot?
Cheers,
Terry
12-17-2017, 07:49 PM   #4
Kerebron's Avatar
I didn't have any problems with mine, but I've heard about few cases when there were some problems with new 55-300 PLM lenses - they were stuck or not functioning properly. Usually unmounting and re-attaching of the lens once or a couple of times rectifies those problems and they never come back. Sometimes a gentle knock or two was needed.
And make sure that the lens is fully open into working position in the first place.
12-17-2017, 08:02 PM   #5
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by tduell Quote
Cheers,
Terry
Check pg 35 of the operating Manuel regarding retractable lens
12-17-2017, 08:18 PM   #6
I have a k3-II with 55-300 PLM; all works fine. If I do not retract the lens and I turn on camera it gives me an error message: "Shutter release disabled.........."
the "zoom ring" is further away from the camera- would be locked if not retracted. However, the focus ring moves, even if not retracted.
If the lens is not mounted properly; it will ask for focal length input.
Hope this helps
12-17-2017, 08:27 PM   #7
BWG
Double check the firmware update. That’s often the problem.
12-17-2017, 08:33 PM   #8
Check to see that the lens is properly mounted and fully extended. Without power, it can't even focus manually.
Also note that the AF is almost instant and pretty much inaudible. The best way to test it is to focus on something distant, then on something close, and check to see if both are in focus.
12-17-2017, 09:19 PM   #9
QuoteOriginally posted by Aslyfox Quote
That's not Manuel from Fawlty Towers is it?
Cheers,
Terry
12-17-2017, 10:18 PM   #10
Kerebron's Avatar
Cheers,
Terry
I'm sure it's not. That one was inoperable.
12-18-2017, 04:49 AM   #11
Seeker of Knowledge
aslyfox's Avatar
Cheers,
Terry
a few thoughts
nice reference
I do know the reference without looking it up
" let he who is without sin, throw the first stone " - meaning anyone who has ever posted a typo shouldn't talk
12-18-2017, 07:18 AM   #12
Imp
Imp's Avatar
that's not manuel from fawlty towers is it?
Cheers,
terry
Baaaasil!!!
12-18-2017, 02:18 PM   #13
a few thoughts
nice reference
No stones, just an amusing connection.
Typos don't bother, but bad spelling does a bit. I reckon the most common example is 'loose' instead of 'lose', it's rife.
Cheers,
Terry
12-18-2017, 05:56 PM   #14
Hi folks,
First of all, thanks for advices!
I extend up to 300 before shot (several times)...
I updated firmware several times...
I unmounted and re-attached lens several times...
I gentle knocks a few times ($400...) but still not working...
And I tried others configurations. If I use P, Sv, Tv, Av, TAv, M, B or X + AF + set AF.S Setting to Release-priority it shots without focus.
Any other idea?
Tks
12-18-2017, 08:43 PM   #15
Des
Des's Avatar
QuoteOriginally posted by andrerio Quote
Any other idea?
Clean the contacts on the lens and the camera?
Do you know someone else with a Pentax K-mount camera? They could test the lens - which would help determine whether it is working. If it is, the problem must be with the camera.
If you don't, either ask here whether there is a forum member in your part of Brazil, or take it to a service centre that has a Pentax body to test with.
camera, focus, hd, hd pentax-da, hd pentax-da 55-300mm, k-3 ii, mode, pentax help, pentax-da, photography, plm, plm wr, re, troubleshooting, wr
Trouble with KP and HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE talgarik Troubleshooting and Beginner Help 37 05-01-2018 01:15 PM
Pentax HD-DA 4.5-6.3 55-300 ED PLM WR RE new K mount Norman P. Pentax SLR Lens Discussion 4 06-24-2017 02:42 AM
Pentax HD PENTAX-DA 55-300mm f/4.5-6.3 ED PLM WR RE Lens $402! Spodeworld Pentax Price Watch 6 06-09-2017 09:09 AM
Question Review of HD DA 55-300/4.5-6.3 ED PLM WR RE ? fwcetus Site Suggestions and Help 2 01-29-2017 05:52 AM
HD Pentax-DA 55-300MM F4.5-6.3 ED PLM WR RE for 306 EUR beholder3 Pentax Price Watch 3 11-18-2016 05:08 AM
All times are GMT -7. The time now is 04:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
