Originally posted by Kombivan The iso in the dslr cameras is nothing like the iso in film cameras in film you drop the iso to get better detail with ISO you increase the iso to get more detail and as a bonus you get a faster shutter speed avoiding camera shake. Very happy with this find. this is why some images look blan with the background you need more ISO for an overcast day set to cloud and ISO 2000 will give good background detail 800 won't. let alone 80.
With respect, that's not actually the case. Selecting a lower ISO setting on a digital camera reduces the sensitivity to light, and a higher ISO increases the sensitivity - just like switching to lower or higher ISO film in a film camera. As you increase the ISO setting, that will also increase the amount of noise in the recorded image, which negatively impacts detail. It will also reduce the dynamic range that the camera can record, but that's a separate discussion.
You might occasionally have a perception of slightly greater detail at higher ISO settings due to the fine luminance noise it introduces, but that's an illusion caused by the way your eyes and brain interpret the picture. In fact, the detail is reduced. For maximum detail, you need to use the lowest ISO setting practical for the shot.
You're quite right that increasing the ISO will allow you to use a faster shutter speed for any given aperture setting. If you're at ISO 100, with the aperture at f/5.6 and a shutter speed of 1/80s gives correct exposure, when you increase ISO to 200, you'll use a shutter speed of 1/160s at the same aperture. It's the classic "exposure triangle" of ISO, aperture & shutter spped.
Hope this helps
