Originally posted by gerardbaron I just purchased two Yonghuo RF603N II. They do not trigger my Pentax 360FGZ.
I try with a Nikon flash: no problem.
Any suggestions before I return those transmitters.
Thanks
My RF603N II does the same thing also, this is with the AF540FGZ. The way to make it work is to slide the flash back couple millimeters.
The 603N II hot shoe is little different from Pentax hot shoe, it is for "N" after all.
The center contact on the YN is slightly smaller and the YN does not have the little back-stop like the pantax cameras have, this allows the flash to slide too far in causing the center contacts to miss and not make contact.
