Originally posted by foxsp
"Just1MoreDave " and "stevebrot" I'm glad you mentioned the KatzEye screen. I too have one in this camera. It is the split image one. That could make sense that it could be causing the problem. If Pentax changed the algorithm for spot metering in V1.07, the split image prisms might be interfering with metering. But when using spot metering with flash, the exposure is correct. I kept the original focus screen so when I locate it I'll put it back in and check this to see if it's the problem.
Like I said, the camera behavior changed between V1.06 and V1.07 firmware.
Thanks everyone.
It is hard to say regarding the firmware version, though I do know that KatzEye has consistently offered a strong caution regarding spot metering since at least 2008 when I first purchased from them. The interference with spotmetering is well known and is one of the reasons (historically) why spot metering has been conspicuously absent from film SLRs having center region focus aides for about as far back as TTL metering was offered.* If there was a K-5IIs firmware version that was capable of detecting and compensating for the issue with a 3rd-party screen, that would be fairly extraordinary and noteworthy. Ditto for P-TTL flash metering with the split-image. FWIW, my K-3 overexposes badly at f/3.5 when spot-metered with the KatzEye. Set aperture on your K-5IIs to f/3.5 with spot meter and see how P-TTL goes.
BTW...what lens are you using for this thread and the example images on the other thread (
LINK to post from April 2014).
* My Mamiya/Sekor 1000 DTL offers dual spot/averaging metering, but the spot meter reads at bottom center of the frame rather that the center microprism.
