Originally posted by Hidrieus What are the different results?
Hi Hidrieus, unless you are having problems with white objects not appearing white on a properly exposed photograph, you do not need to adjust your settings. If you set your white balance manually, as in changing your WB to suit the light source ( daylight, cloudy, tungsten globes etc ) then you must be on the right setting for your images to have true color. I have given a link below that explains it much better than I can. Good luck.
Understanding White Balance
