Quote: Major features subsequently added through firmware updates: - Version 1.30: Support for lenses with KAF4 mount, i.e. lenses that have foregone the mechanical stop-down lever
- Version 1.20: Support for AF buttons on the barrel of the HD Pentax-D FA 150-450mm lens
- Version 1.10: Diffraction Correction
- Version 1.03: Support for HD Pentax-DA Rear Converter 1.4X AW
- Version 1.02: AA Filter Bracketing
Issue is not with auto focus but with the lack of support for a mechanical stop down lever on PLM lenses. As I understand it. Not sure what else to say. I have no Sigma lenses but as far as I know HSM has worked on all cameras back to K10D.
---------- Post added 01-07-18 at 03:11 PM ----------
Originally posted by geoffb All I'm after is a mid priced (good) tele lens (if such a beast exists)
For consumer lenses the DA 55-300 is about as good as it gets in K-mount. The newer PLM version is faster focusing but either of the older versions will work just fine, especially if you use manual focus anyway. In fact if you are going to use manual focus then there is IMHO no reason to get the more expensive PLM version anyway.
The next step up would be the DA*60-250 which is in another class for size, weight, price and quality.
