01-10-2018, 10:58 PM   #1
Is this Fungus or Haze?
Recently bought a Good Condition Tokina 28-70 F3.5 to 4.5 lens for Pentax from UsedPhotoPro.com. Lens was posted as having some fungus and was sold @ $11 + free shipping.
Took a chance, Lens seems sharp with my indoor testing.
The rear element shows ring kind of layer, can't figure out if its haze or fungus.
Here are few pics of the lens with light thru back of the lens.
Pics taken with this lens seems to come out well with good contrast and brightness.
Haven't shot Outdoor yet.
How do I clean it? What is it actually?
BTW well built lens.
Pixel 2 XL  Photo
Pixel 2 XL  Photo
01-11-2018, 01:24 AM - 1 Like   #2
Looks like element separation to me. Effectively a form of haze. CAn only be repaired by dismantling, separating elements, cleaning off the affected glue and re-glueing. Not an easy task for a zoom lens generally, but, work the effort if you want to get 'cheap' lenses and repair yourself.
01-11-2018, 05:19 AM - 1 Like   #3
twilhelm's Avatar
It does look like separation. It may take a bit of searching, but there are a couple of threads on here about repairing lens separation, including recommended glues.
It’s a good lens, but the time and money invested may be more than a good copy would cost.
01-11-2018, 08:46 AM   #4
hmm, it won't damage my camera right?
Indoor with multiple light sources and wide open, the pics look 'hazy', but use fill flash or stop it down couple pics turn out ok. I tried the same settings with another 35-135 lens and that one wide open came out well with good contrast.
May be effect of this extra stuff on the back of the lens?
I also see some black liquid thing flown out of the rear and dry now.
Sample pics taken (good lighting) with this Lens and K50
70mm @ F4.5
70mm @ F5.6
70mm @ F7.1
28mm @ F3.5
28mm @ F4.5
PENTAX K-50  Photo
PENTAX K-50  Photo
PENTAX K-50  Photo
PENTAX K-50  Photo
PENTAX K-50  Photo
01-11-2018, 07:23 PM   #5
twilhelm's Avatar
No, it will not damage your camera. But what do you mean by black liquid? Is it on the outside or inside of the camera?
01-11-2018, 08:52 PM   #6
QuoteOriginally posted by twilhelm Quote
It's outside of the Rear element of the lens.
01-12-2018, 05:36 AM   #7
twilhelm's Avatar
Looking at my Tokina 28-70 (older version but similar build) it sounds like oil from the aperture blades. Now I’m wondering if your lens didn’t get baked, as in left in a very hot car for a long period of time.
01-12-2018, 08:29 AM   #8
Looking at my Tokina 28-70 (older version but similar build) it sounds like oil from the aperture blades. Now Iím wondering if your lens didnít get baked, as in left in a very hot car for a long period of time.
No idea. Oh well for $11 + free shipping the lens still takes good pics, will try out more this weekend.
01-16-2018, 03:59 PM - 1 Like   #9
It looks like a classical case of "Newton's Rings" named after the famous English physicist Isaac Newton. It occurs when a curve optical surface touches a flat glass surface causing a varying circular space between the two. Light passing through causes optical interference patterns that take the form of concentric rings. I think that lens element separation moves the two surfaces into close contact causing the ring pattern. Exactly how this happens I don't know. It will depend on the final placement of the individual glass elements after lens separation occurs. Google Newton's rings to learn more.
01-16-2018, 08:04 PM   #10
Whatever the problem is this lens still takes very good pictures. I did a photo shoot inside our temple and all the pictures turned out very well and some amazing. Thru the view finder the scene seems less bright when compared to other normal lens.
Anyway the lens is sharp wide open too, with good contrast.
For $11 I can't complain.
I wish I can post some pics that I took, but since it's religious don't know if the rules of this site allow to post.
01-25-2018, 03:26 AM - 1 Like   #11
fmw
Fungus is easy to remove. Element separation such as you have, though, is quite tricky and an error in getting the elements back exactly the same way can make things worse. I don't recommend you try it. Since the lens is getting the job done for you, use it as it is.
camera, fungus, lens, pentax help, photography, pics, troubleshooting
Fungus, haze or bubbles lucius Troubleshooting and Beginner Help 3 01-03-2017 12:24 PM
Light haze - is the bargain second hand lens with haze worth it? awscreo Pentax SLR Lens Discussion 7 11-05-2016 12:56 PM
Is this fungus or haze in this older lens? Samsa Pentax SLR Lens Discussion 6 07-29-2016 12:50 PM
Fungus? Haze? mainstreetexile Pentax SLR Lens Discussion 22 12-27-2014 03:59 AM
Fungus or Haze on lens RollsUp Troubleshooting and Beginner Help 11 03-28-2011 05:29 PM
All times are GMT -7. The time now is 10:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
