01-14-2018, 08:26 AM   #16
QuoteOriginally posted by blende8 Quote
I tried to reproduce this with my screens, but wasn't able to see it.
And you really see it only on the Google web page?
It turns out that not only Google but web pages that have a light interface from edge to edge.
01-14-2018, 09:45 AM   #17
01-14-2018, 10:41 AM   #18
amoringello's Avatar
QuoteOriginally posted by unapye Quote
What is the shutter speed? Maybe increase your f-stop to slow down your shutter speed and see if that makes a difference.
Or use Manual mode to ensure your shutter speed doesn't change dependent upon the screen color (brightness).
I suspect, like others, that the screen refresh rate is the main culprit and is in conflict with faster shutter speeds.
01-14-2018, 12:30 PM   #19
Shuter speed was 1/90 but I tried different speeds like 4s and I used manual.
Why do you think that this is about screen refreshing?
Do different websites cause different refreshing? Is there any other refresh rate at the top of present page than at the bottom?
And if a reason is the screen refreshing why it affects an area beyond the monitor ?
01-14-2018, 01:04 PM   #20
Not specifically about screen refresh rate so much as the combination with shutter speed. If your camera is in some sort of auto mode, the shutter speed will change with the amount of light from the screen.
Thus a nearly-all-white screen like Google is going to put out more light and possibly cause your shutter speed to increase. Darker screens may cause a longer shutter speed.
Slower shutter will be more likely to allow multiple screen-refreshes to overlap and help hide variance in pixel brightness which would occur during refresh. The high speed variations caused by refresh could cause pixel-shift to work poorly when putting things back together.
There's a lot of If's and possible places for variation. Which is why some are asking if this occurs for static objects.
Also why I mentioned using Manual setting on the camera to make sure your shutter speed does not vary from image to image.
bar, browser, camera, focus, google, mode, pentax help, photography, picture, pictures, pixel shift mode, sd, shift, troubleshooting
K1/Samyang 24mm Tilt/Shift and Pixel Shift DDoram Pentax K-1 3 06-25-2016 02:05 PM
An analysis of the Pentax K-1's "Pixel Shift Resolution" mode - Image resource Oli86 Pentax K-1 7 05-06-2016 07:19 AM
Can't use Pixel Shift Resolution in B mode astrojim Photographic Technique 14 03-29-2016 04:11 PM
K-1 FF Pixel Shift--Disrupting the Status Quo? gavinhw Pentax Full Frame 125 03-03-2016 03:08 PM
Is Av Shift and/or Tv Shift in TAv Mode possible. robert_s Pentax K-5 3 09-30-2011 09:03 AM
All times are GMT -7. The time now is 03:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
