Originally posted by unapye Shuter speed was 1/90 but I tried different speeds like 4s and I used manual.
Why do you think that this is about screen refreshing?
Do different websites cause different refreshing? Is there any other refresh rate at the top of present page than at the bottom?
And if a reason is the screen refreshing why it affects an area beyond the monitor ?
Not specifically about screen refresh rate so much as the combination with shutter speed. If your camera is in some sort of auto mode, the shutter speed will change with the amount of light from the screen.
Thus a nearly-all-white screen like Google is going to put out more light and possibly cause your shutter speed to increase. Darker screens may cause a longer shutter speed.
Slower shutter will be more likely to allow multiple screen-refreshes to overlap and help hide variance in pixel brightness which would occur during refresh. The high speed variations caused by refresh could cause pixel-shift to work poorly when putting things back together.
There's a lot of If's and possible places for variation. Which is why some are asking if this occurs for static objects.
Also why I mentioned using Manual setting on the camera to make sure your shutter speed does not vary from image to image.
