Well now that your K-30 is being repaired, it should hold you for a good while. I think it is a wise move. This will make it a salable item after you've saved for an upgrade. In the meantime, the price of a new KP should come down yet more, which would definitely be an upgrade in many ways. If you hang on until the end of its model run, you could get one at a reduced closeout price to clear inventory for the next model. The info regarding design and its essentially metal-body pro-level construction has been the KP is not prone to the aperture failure problem.
