01-24-2018, 01:36 AM   #16
QuoteOriginally posted by trip Quote
Itís turned as far as it can go- until it clicks/locks into place. Iíve remoubted the thing about a hundred times by now haha... I really wish I had another af lens with me to test and rule out a fault with the camera!! :/
---------- Post added 22-01-18 at 14:49 ----------
The sensor is definitely capturing images; I can take photos- the lens jusy makes no attempt to focus, and Iím unable to focus manually. Power issue I guess? Or the lens has somehow jammed since its last use?
I just tested an out of warranty 55-300plm on 2 K-3's and on my K-3II, no focusing. I used this lens 1 month ago so I know it did work on my K-3II. The manual focus ring is electronic so no direct coupling with the internal focus elements. Estimated cost of repair is $60 less than a new lens. I would request warranty service for your lens, a new lens has been ordered to replace the faulty one I tested.
01-24-2018, 02:22 AM   #17
ffking's Avatar
Another shot in the dark, and not a solution to the problem, but there is a known risk of the vibration of aircraft shaking screws loose in cameras and lenses - not that it's ever happened to me - does anyone who pulls lenses apart know if there is anything that might make the lens vulnerable to that in terms of this outcome?
camera, da, da 55-300 wr, day, focus, focus da, issue, k3, lens, pentax help, photography, plane, plm, power, sensor, troubleshooting, wr, wr plm
55-200, 55-200 WR, 55-300, 55-300 PLM, etc, which telezoom I should get? Bui Pentax SLR Lens Discussion 67 06-25-2018 08:15 PM
DA 55-300 vs 55-300 PLM John A. Pentax SLR Lens Discussion 18 11-03-2017 06:18 AM
55-300 PLM or non-PLM version to K-1? Vignetting etc? HankVonHeaven Pentax SLR Lens Discussion 7 01-29-2017 09:54 AM
18-135 or new 55-300 PLM as an WR upgrade for old DA 55-300 - HELP :) gelokrol Pentax SLR Lens Discussion 6 12-15-2016 11:53 AM
Pentax DA 55-300/4.5-6.3 ED WM PLM WR RE Compatibility stevebrot Ask B&H Photo! 3 11-08-2016 06:10 PM
All times are GMT -7. The time now is 08:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
