01-21-2018, 01:02 PM   #1
K lenses mounted to screw in body
Hello Forum
I am new here.
I have purchased a Pentax bellows with M42 screw mounts.
I have fitted the adaptor on by K3 and attached the bellows to that.
Is it possible to fit a K lens to the other end of the bellows i.e is there an adaptor which allows new lenses to be mounted to old screw in bodies?
Or should I look for a screw in lens?
I would ideally like to mount my 100mm prime macro to the bellows.
Thanks all.
01-21-2018, 01:10 PM   #2
Nope, the K lens mount is simply too big. But if you got the K-mount bellows, you could adapt all M42 lenses to it.
01-21-2018, 03:21 PM   #3
QuoteOriginally posted by Davidi Quote
Hello Forum
I am new here.
Thanks all.
No adapter off the shelf - but you do have options.
Option 1 - Genuine Pentax
Get the original Bellows Takumar 100 which was designed to be used with the bellows. The Bellows 100 will even focus right through to infinity on the bellows.
Option 2 - genuine Pentax components
Purchase a set of Auto Bellows K / Auto Bellows M. This gives you much versatility. The camera mounts & front lens standards can be interchanged with each other. This will give you M42 camera - K lens or K camera with M42 lens. It also gives you the possibility with a bit more fiddling with components to make a set of 'super bellows' by using the 2 bellows joined end on end without any destructive modification. Just be wary of the late auto Bellows A as they used a fractionally smaller focus rail which is not compatible.
Option 3 - Non Pentax components.
Modify the mount on a extension tube. The easiest is to start with a K mount tube & replace the camera side mount with M42. Many of the off brand / after market extension tubes have the mounts fixed by screws. If you are lucky enough to find a manufacturer that produces both M42 & K Mount variants it is just a simple matter of doing a mount change with a few screws. Many of the cheap Chinese tubes available now work well for this. I have used Soligor tubes for my adapters.
Option 4 - Genuine Pentax components
Pentax had a adapter for the ring flash to allow it to be used on reverse mounted lenses called Reverse Ring Light adapter K. It can be used (reversed to the way it was designed) as a base to mount a M42 adapter to the other side. However this is not really a option due to the scarcity of them nowadays.
01-21-2018, 03:51 PM   #4
I went round and round with this same thing a while back.
I finally ended up with a k mount bellows. Just make sure it comes with the camera mount, too...
And the 100 bellows macro is pretty cool, though of limited utility...
-Eric
01-21-2018, 05:37 PM   #5
Na Horuk's Avatar
K does not fit into m42 because K has much larger diameter. This is the reason why it works so well the other way around, from K to m42.
At this point, your best bet is to buy a good m42 lens. One with good central sharpness and low price is the Helios 44-2 or newer (whatever version of this you can find; most are m42, but some are other mount so be careful). Affordable lens, sharp centre once stopped down, and you can use it as a portrait or artsy bokeh lens as well.
Or look for other m42 primes, many around 35mm and 50mm are quite affordable. More affordable than trying to find or make that adapter you want
01-21-2018, 07:14 PM   #6
Not a Number's Avatar
There is no off the shelf adapter but this company will fabricate a custom one for you for $201 USD. It will add a minimum of 18mm extension to your bellows. You may get some vignetting depending on the lens and amount of bellows extension due to the smaller opening for screw-mount lenses.
PreciseParts Build-An-Adapter
You would be better off buying a set of K-mount auto bellows for that price.
01-22-2018, 01:37 AM   #7
You might look at the screw mount macro lenses in the lens database. Here are a couple. They should give a fairly flat field. Plus, with the Pentax M42 adapter, you can use it with your K-mount body. The 100mm F4 Macro is 0.5x magnification. The 50mm F4 has two flavors, 0.5x and 1.0x. The 1.0x is harder to find, and a bit more expensive. Since you already have a 100mm macro, perhaps a 50mm macro with the adapter might fit the ticket. That said, I find that my A 50mm macro rarely sees daylight since I got a 100mm macro.
Both the lenses below have good reviews, and either should serve you well, depending on your specific needs, both on the bellows and on your camera body.
Super-Multi-Coated Macro-Takumar 100mm F4 Macro
S-M-C/Super Macro-Takumar 50mm F4
01-22-2018, 10:54 AM   #8
Managed it.
An old K teleconverter lenses removed from it.
Genuine Pentax M42 to K adaptor (selling for 18.00 on amazon).
Bellows onto the adaptor.
Penatacon 1.8/50 onto the other end.
The Pentacon will do until I get something better.
Thanks all.
adaptor, adaptors, bellows, camera, k mounts, lens, lenses, pentax help, photography, screw, screw mounts, troubleshooting
Nature Silver K-3 II with DA 50mm 1.8 mounted and K-5 with F 50mm 1.7 mounted (BIF in Snow) Lmcfarrin Post Your Photos! 1 12-25-2017 03:41 PM
Possible to mount a ring flash to a reverse mounted Takumar 50 1.4 screw mount lens. Washingtonstater Photographic Technique 3 09-29-2013 08:32 PM
Monopod: 3/8" adapter screw stuck on the 1/4" screw !! jpzk Pentax Camera and Field Accessories 29 04-22-2012 08:00 PM
Screw driven AF cameras. More high end = better screw drive? Reportage Pentax DSLR Discussion 13 09-01-2011 08:38 AM
180 and 300 CZJ lenses mounted on a Pentax 67 ARCASIA Pentax Medium Format 17 12-27-2010 02:26 AM
All times are GMT -7. The time now is 05:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
