Originally posted by Elizabeth I've got a very beginner's problem.
I finally picked up and started learning about my new K-3 ii after being intimidated by it for many many many months. It is a bit more complicated than my beloved Pentax MX. I am stuck at formatting the Memory Card, which is a Pentax 16GB FLUCARD PRO that came with the camera. The "Memory" command on Menu" #4 does not turn on. The camera is not registering that the memory card is inserted into the camera. Neither slot works. Instead the "Memory" command is colored grey, not white, like all of the other commands. When I turn on the camera the "Memory Card Access Lamp" flickers orange a few times then turns off. When the card is inserted into the 2nd slot, the lamp flashes once. When the card in the 1st slot, it flashes twice. When I turn on the camera the lamp just blinks quickly a few times. Do the flashes mean anything? How should the lamp work with a memory card inserted?
Guessing I have a bad memory card. Or maybe I destroyed it way back when. I read that one has to have the camera off when inserting the memory card. Maybe I inserted it with the camera on.
Also, is this a good memory card? It has a mixed review on Google. Did notice that it is expensive, $99. Is it normal that the card has wifi access to a computer? This seems special.
A lot of beginner questions. Appreciate your help. Thanks a lot.
Hi, Elizabeth. First, the FLUCARD is designed to provide WiFi access between the camera and a WiFi network or computer, so in that respect it's working normally. It should always be placed in SD card slot 2, according to the K-3ii manual. Non-FLUCARD SD cards can go in either or both slots. In order to format the card, you need to select submenu 4 of the menu with the wrench at the top. The second item from the bottom controls the formatting process. The light on the camera should flicker when a SD card is inserted or removed and, as you said, the camera should be off when you do so in order to avoid corrupting the data on the card.The "Memory" command on Menu #4 of the main menu, which you refer to, controls what camera settings are maintained in the camera's memory when the camera is turned off, and basically has nothing to do with the SD card. Hope this helps.
