01-26-2018, 09:20 AM   #1
KIRON 70-210mm ZOOM LENS f4; Macro 1:4/ Zoomlock
Is the KIRON 70-210mm ZOOM LENS f4; Macro 1:4/ Zoom lock compatible with my Pentax k-3? and also is the KIRON 70-210mm ZOOM LENS f4; Macro 1:4/ Zoom lock any good quality lens?
01-26-2018, 10:06 AM   #2
sergysergy's Avatar
Kiron lenses are well regarded:
Miscellaneous Lenses for Pentax: Zoom Lenses - Pentax Lens Review Database
https://www.pentaxforums.com/userreviews/kiron-70-210mm-f-4-macro-zoomlock.html
They will work on your K-3 provided they are K mount
01-26-2018, 10:28 AM   #3
pres589's Avatar
You may have to enable use of aperture ring in the settings on the camera depending on if the copy you're considering is a PK or PKA mount type. Basically if it doesn't have an A position on the ring, you'll need to enable.
Seems to review well.
01-26-2018, 11:02 AM   #4
Just1MoreDave's Avatar
These lenses might have a large flange/shield next to the aperture lever. If you look at a Pentax lens, the flange is just a little longer than the aperture lever travel - about 5/8" or 16mm long. Longer flanges will run into the SDM contacts in the mount so the lens won't mount on the camera. You can just remove the extended part of the flange. There are a lot of threads on doing this with Vivitar lenses.
You'll have to choose a focal length to enter for SR. I'd go with 135mm because I'm likely to use the lens at that length or longer.
01-26-2018, 12:48 PM   #5
You can check out some comparison images here:
Test classic 70-210mm vintage lenses: vivitar series 1, tamron SP
Good lens IMO!
01-26-2018, 03:04 PM   #6
Otis Memorial Pentaxian
QuoteOriginally posted by marcusBMG Quote
Good lens IMO!
I concur. It certainly has the right to run with the big boys.
70-210mm, 70-210mm zoom lens, f4, k-30, k-50, kiron, kiron 70-210mm, lens, macro, pentax k30, pentax k50
Kiron 70-210mm f4 - the classic MF "zoomlock". One of the best! marcusBMG Pentax SLR Lens Discussion 6 08-29-2017 05:03 AM
For Sale - Sold: DA 50-200mm WR, DAL 18-55mm, Sigma 70-210mm macro zoom, unbranded 70-210mm macro zoom theswiftman Sold Items 2 06-25-2014 06:43 AM
For Sale - Sold: Pentax SMC-A 70-210mm f4 Macro zoom; Pentax A3000 film SLR; Vivitar 28-210mm z NeverSatisfied Sold Items 9 05-14-2010 01:37 PM
All times are GMT -7. The time now is 10:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
