Originally posted by GPZ Did you test it when you came back home to see if it worked correctly?
No. I usually let it warm up slowly in the bag. Then I got busy with kids...
---------- Post added 01-27-18 at 04:07 AM ----------
Originally posted by pjv Hi IgorZ, whenever I used my LX ( don't have it anymore
) in colder temperatures, I removed the batteries, and relied on the electro-mechanical shutter. I found the batteries to be quite unreliable. Shooting totally manual for me was very time consuming though, by the time I used my light meter to get exposure settings, many times the moment had gone. But that was me. I never really got proficient with exposures until I went digital with a K20D. Waiting until my films got developed was sometimes quite disappointing for me.
Good luck.
Huh, haven't thought of that. The batteries were replaced in the spring though... I've shot a couple of rolls since then, but not that many. Or are thry in general unreliable in the cold?
---------- Post added 01-27-18 at 04:11 AM ----------
Originally posted by twilhelm When you warmed it back up, did it work properly? As the LX is getting a bit long in years, it may be time for a good CLA. The lubricants will stiffen with age, and only get worse in the cold. My LX was getting a bit sluggish, especially at shutter speeds below 1/60, but I just had a CLA done and spent a whole day shooting at -10 C with no problems.
Haven't checked it yet. Will try once the sun is out. Thanks for the suggestion. I haven't thought about the sticky grease... I replaced the sticky mirror buffer recently, and they told me they did a CLA, but it wasn't Eric who did it, so I am not sure how much work they actually did... They fixed the sticky mirror problem though.
---------- Post added 01-27-18 at 04:14 AM ----------
Originally posted by pentaxus Aside from the cold, have you used the LX recently? The mirror sits on a rubber piece that gets gooey with age. My LX acted like yours in normal temperatures before I replaced the rubber. How does your camera act now in warm temperature?
Yes, I use the LX quite often. It always works fine, aside from the outing yesterday. I had the sticky mirror fixed recently.
---------- Post added 01-27-18 at 04:16 AM ----------
Originally posted by Wheatfield ^^^this^^^
When my first LX (I own 3) was brand new, I took it and a K1000 out on a Christmas day when it was close to -30ºC. The battery on the LX quit after about 45 minutes, IIRC, but it kept working on mechanical speeds. The K1000 meter quit after an hour, and eventually the shutter froze open. The LX will work in very extreme conditions, providing it has fresh lubricants.
Given the winter we've had, if I can get it to work in - 30 temperatures by replacing the lubricant, I should send it to Eric asap
