01-27-2018, 11:34 AM   #1
Pentax K 3 and Intervalometer
Hello
I begin be ungry, perhaps my fault but I can't use my intervalometer. I want take 10 shots of 2m with an interval of 10s and the camera make 5 shots and the last one i need shut it down. The resilt is only 5 with the last one longer. I belive it does not shut down and the exposure stay in bulb so i need to shut it off.
Anyone can help?
The intervalometer I bought is a generic one with the cable for Pentax similar to the one attached.
Thanks in advance
Antonio
01-27-2018, 03:37 PM - 1 Like   #2
Otis Memorial Pentaxian
Consider what you have set it to do and do a mental walk through the steps. (Hint: most intervalometers time from the start of the first event.)
I have a similar intervalometer to that pictured and to set for a series of 2m exposures with 20s between I must configure:
Delay = 0
Interval = 2m + 20s + time until ready* (the time between shutter presses)
Exposure/"Long" = 2m
Count = 5
In addition, since you are doing B(ulb) mode exposures, you might want to confirm that your camera is configured to use the same B option as the intervalometer. Most operate assuming Option 1 in the Custom menu settings for B meanin a continuous press of the shutter release for the full time. Option two means one press to start and a second to stop; this being the setting to use with most IR remotes.
A third consideration is whether you have Slow Shutter Speed NR enabled (Rec Menu 2). If enabled, there will be a background subtract step equal to the time of the exposure, effectively doubling the exposure cycle.
Fourth is in regards to the cable end on your intervalometer. For your K-3, it should look like the photo below. You already know that, but I added the comment for the benefit of future readers of this thread.
I hope this helps.
* This is usually not very long, assuming the background subtract option is turned off.
01-27-2018, 03:45 PM   #3
It occurred to me that operation might be pretty much the same as for my remote and that my review of that unit might be helpful. I included detailed information on usage.
Bower LCD Timer and Remote Shutter Release (Model RCLC1R) reviews - Pentax Camera Accessory Review Database
01-27-2018, 07:19 PM   #4
Delay = 0
Count = 5
Fourth is in regards to the cable end on your intervalometer. For your K-3, it should look like the photo below. You already know that, but I added the comment for the benefit of future readers of this thread.I hope this helps.
Hello
You are wright. As I said my error eventualy and I confirm. I should choose option 1 in Bulb mode, as I have configured it to option 2.
Problem solved.
Thanks to all
Regards
Antonio.
camera, intervalometer, pentax, pentax help, photography, shots, troubleshooting
Pentax K3 ii intervalometer stops davinci Pentax K-3 9 08-15-2018 08:43 PM
Image stabilization and intervalometer barondla Pentax Q 2 02-08-2017 04:20 PM
Urgent help requested: Intervalometer and O-GPS1 DeadJohn Pentax Camera and Field Accessories 3 03-26-2013 11:35 AM
Long exposures and IR intervalometer problems maxwolfie Pentax DSLR Discussion 4 07-29-2012 04:58 PM
Camera shake bug when wireless remote shutter and intervalometer are both enabled? DeadJohn Troubleshooting and Beginner Help 2 09-01-2011 07:20 PM
All times are GMT -7. The time now is 06:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
