Show Printable Version 4 Likes Search this Thread
02-04-2018, 06:07 PM   #16
With CP+ around the corner, I'd spend the next weeks reading up on the current models and see if there isn't something else to compare to in a month. There isn't any concrete news, but I think many would agree that the tea leaves appear to be favorable for some new cameras or announcements shortly.
02-04-2018, 06:13 PM   #17
Once you get your K-30 back, if you are interested in upping your class of camera and in imaging improvement, save up for a KP. You will have a better-built, more advanced camera in many ways, superior control set, excellent low-light/higher ISO performance, higher resolution, and much more. Using a high-quality lens with it is also important for availing yourself of its potential. The K-5 series has a similar sensor to your K-30, so if you go that route, get a K-5 IIs, which eliminates the AA filter for better image definition. In either case, be sure to set your camera's sharpening to "F" for Fine Sharpening in the Custom Image menus, for better detail in your images.
02-04-2018, 06:26 PM   #18
Otis Memorial Pentaxian
My suggestion would be a K-3II while new stock lasts (recently discontinued by Pentax).
02-04-2018, 06:44 PM   #19
Seeker of Knowledge
aslyfox's Avatar
Some thing to think about
[ how much time to spend thinking is up to the buyer ]
but as I understand it, the " latest and greatest " [ so to speak ] changes in Pentax lenses is the PLM - Pulse Motor (PLM) system powering the autofocus and the KAF4 mount.
" PLM - "PLM" means this lens uses a pulse motor, which is near-silent and substantially faster than both the older screw-drive design and Pentax's other silent motors.
Read more at: https://www.pentaxforums.com/reviews/hd-pentax-da-55-300mm-f45-63-ed-plm-wr/specifications.html#ixzz56C4agseG"
" The KAF4 Mount and Compatibility
The lens mount is made of metal, and encircled by the trademark bright orange WR gasket, designed to keep water and dust away from your sensor and other delicate components. If you look closely at the back of the lens, you'll also notice that there's no aperture stop-down lever. That's due to the brand-new KAF4 mount designation, which introduces fully electronic aperture control to Pentax lenses.
The upside to the move to KAF4 is that the lens now has fewer moving parts, and that aperture control makes less noise. If you don't have a physical aperture lever, it can't get jammed. The downside is that this lens can only be used by cameras that recognize the new KAF4 mount. As of early 2017, the list includes the K-1, K-3, K-3 II, K-S2, K-S1, K-50, K-70, and KP. All future bodies should also be KAF4-compatible. All of the aforementioned cameras save the K-70 and KP first need a firmware update to support this lens. "
Read more at: HD Pentax-DA 55-300mm F4.5-6.3 PLM WR RE Review - Construction and Handling | PentaxForums.com Reviews
_______________________
This chart shows which Pentax Camera Bodies - the K 1, K-3, K-3 II, K-50, K-70, K-S1, K-S2 - can function with such a system ( and keep in mind, currently only one Pentax lens uses it )
" KAF4: This is a KAF3 mount without an aperture stop down lever. Lenses with the KAF4 mount will only work on camera bodies that support electronic aperture control (cameras from 2013 and newer, except for the K-500). "
The Pentax Camera Lens Compatibility Chart
___________________________________________________________________
how many future Pentax lenses will feature PLM and the KAF4 mount - I have no idea
but if you don't invest in one of the cameras listed above, such lenses will not work if my understanding is correct
do you need the " latest and greatest " development in a Pentax lens, not necessarily but you might want it
02-04-2018, 07:11 PM   #20
I have the K-50 which is same as the K-30 with a different skin, I like the light weight and simplicity of it. But my K-3 with same lens beats the K-50, 95% of the time in terms of focus accuracy and image quality. This is just my experience.
If money is tight you can pick a used/almost brand new K-3 for dirt cheap now, very reliable camera.
I am saving for K-1, someday when family don't drain my wallet....
02-04-2018, 10:35 PM   #21
Alex645's Avatar
QuoteOriginally posted by Dean1966 Quote
What is the best Pentax Camera out there besides the Pentax K-30 when it comes to shooting Portrait, Weddings, Landscapes, and Concerts?
Dean, What lenses do you have for the K-30? Often it is more a matter of having the best lenses for the subject than it is the camera.
If money is not a factor, then I would say THE best Pentax for everything you mentioned (except concerts) would be a 645Z. If all four of your categories are important, then the K-1.
If money is a factor, the K-70 is the least expensive new Pentax that will work fine with your current lenses, but will be a significant upgrade from your K-30.
02-04-2018, 10:42 PM   #22
I'd go the KP
02-05-2018, 02:52 AM   #23
chrism888's Avatar
The best camera is the one you currently own, more than likely, much bigger gains will be achieved by reviewing and then improving your technique and the glass you currently use.
camera, glass, pentax help, photography, technique, troubleshooting
Please help me choose a new (camera!) body robertmillerphoto Pentax DSLR Discussion 11 02-27-2016 09:54 AM
Nature Please help me choose best photo for contest frogoutofwater Photo Critique 24 06-25-2014 04:53 PM
Help me choose, is newer better? CWyatt Pentax SLR Lens Discussion 10 07-18-2009 06:13 PM
Bayon near Angkor Wat - help me choose please mike.hiran Post Your Photos! 5 04-13-2009 03:47 PM
Please help me choose a new lens for my K100D missnewzealand Pentax DSLR Discussion 13 01-14-2008 07:52 PM
All times are GMT -7. The time now is 05:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
