Originally posted by SSGGeezer as it closes down to a smaller aperture, that it may not always form a perfect shape but looking with my eyes it is even worse than how it appears in the picture.
The lens takes very nice images but now I am concerned. It is in warrantee from the seller but that is a pain in the rear to deal with.
It is definitely grease sticking on some of the aperture blades which need cleaning. If you shoot wide open, itʻs no big deal, but starting around f/4, you will get over exposures and some wonky diffraction and less depth of field....plus oddly shaped bokeh.
I would send it back because although it sometimes will not be an issue, it will probably only get worse. Once it is out of warranty, itʻs going to cost nearly $200 to get that fixed. If you love the lens, and the seller is KEH, ask them if they can fix it. In other words, you donʻt want it refunded....just fixed. I think theyʻd be more likely to help you with that now, than closer to the 6 month warranty end.
