Originally posted by Joyce Keay Hi, I had a recent disaster with my K-70 - camera fell off of tripod, screen broke off. When I had the camera six months, it failed to work on a winter photo shoot. Sent it to Precision. They cleaned it and adjusted it but the comment on the return paper work makes me think they had no idea what caused it. For this recent disaster, Advance Camera says autofocus motor is jammed plus they can't get the part to fix the screen/hinge and will have to send it to the factory for repair. I have a protection plan but I've been reading the recent reviews for it and figure they will try to weasel out of it. My photo teacher figures repairs will probably be around $300-400 and that I should think about the K-1. I see Pentax has announced the K-1 Mark II becoming available in April from Adorama. I'm trying to decide between just getting a new K-70 body or getting a K-1 body (either from Amazon not Adorama), but not waiting for the K-1 Mark Ii. Evidently there will be some sort of upgrade available for K-1 owners to incorporate K-1 Mark II functions but I will not want to do that. One other thing is worrying me is that I don't know how confident I can be that the factory will uncover everything that could have been harmed by the fall off the tripod. This time around I will call the outfit that insures my car and house and insure my gear through them. Sooooooo, what do you think? Thanks.
If you are going to insure, make sure you have a very comprehensive plan that includes "unexplained loss" or words to that effect, and that gives full replacement value. A camera that has been impacted hard enough to make it fail is a 50:50 chance of being a write off. They might be able to fix the obvious problem, but six months later something else can go wrong, and you are back on the repair train, and it likely won't be covered under the initial repair warranty.
As for what to buy, once you have a full frame, it's not likely you will go back to a smaller format camera.
I was one of those people that figured it wouldn't make much difference, but the jump from APS-C to 35mm is actually quite big. There is a 3 dimensionality to the K1 files (I had a K3 prior) that is more than just the increase in pixel count. For myself, were I in your position, I would jump for the K1II.
