03-02-2018, 01:42 PM   #91
2 thumbs up, Terry- nice going. Enjoy!
03-02-2018, 02:04 PM - 1 Like   #92
monochrome has already answered this but i will add one thing. Getting better images depends on your skill with a raw converter. If you choose inappropriate settings you can end up with an image that is worse than the camera produced jpeg. Raw does not by itself produce better images
Hi Peter,
I finally figured out how to increase sharpness of my jpegs. Both Natural and Bright are increased to 2. The default was already one. BTW, I was playing around with my 43, yesterday. I wanted to test the focusing accuracy, and there was a very colorful box on my kitchen table. I shot it at 1.9. The shot was amazing. The auto focus was dead on accurate. Nothing else in the picture was in focus. The colors were beautiful. I love that lens!
Terry
---------- Post added 03-02-18 at 03:00 PM ----------
QuoteOriginally posted by mikesbike Quote
Mike,
Now that the adjustments are made, where do you suggest I leave it, on Bright?
Thanks
03-02-2018, 03:15 PM   #93
Or, do I try to match it to what I'm shooting?
03-02-2018, 07:23 PM   #94
Just leave it on Bright for most everything. That is the best all-around setting, which is why it is the default chosen by Pentax.
If you are doing people shots, and they seem to have too much blush in skin tones, or too much red in flowers, switch to Natural, which will reduce color saturation. But sometimes when people are looking a bit pale, the extra slight blush might actually be flattering, so if it looks good, leave it on "Bright". For very high contrast scenes, Natural is likely a preferable choice.
For doing actual portraits, you might consider switching to the Portrait category instead of Bright or Natural. The palette is preset for that purpose, with less detail for smoother skin when that is needed. No need to adjust anything in this category. But it is only for that, so when done doing portraitures, be sure to switch back to "Bright". However, switching to Portrait is not always necessary. Sometimes you want a more robust look, and more detail in facial shots.
03-03-2018, 05:19 AM   #95
Mike or Paul,
Is this how it should look?
Terry
D-LUX 5  Photo
D-LUX 5  Photo
03-03-2018, 05:32 AM   #96
monochrome's Avatar
Looks good. And it (#1) is a curiously interesting photograph in its own right. Caught my eye immediately.
03-03-2018, 06:06 AM   #97
Terry: A RAW file is the actual data output by the sensor converted into a processable data string. Your camera - or external software such as Photoshop or Lightroom (or dozens of others)- ‘develops’ the RAW into a viewable / printable jpeg. A RAW is analogous to a film negative (for print films, not positives for transparencies) that has been developed from the raw film. Making an enlargement and printing it on photo paper (using techniques and skill to alter the final print) is equivalent to creating a jpeg.
We’re suggesting for now you let the camera create your jpegs.
The section on using the 4-Way Controller is your starting point. The reference to the setting screen for the processing defaults is where you will see the settings. The manual is very spare. It isn’t a How-To Guide*.
- Paul
At a point someone will reply RTFM. Take that in good spirit.
Paul,
Please look at my last post. Thank you.
Terry
---------- Post added 03-03-18 at 06:09 AM ----------
Great,
Thank you.
Terry
03-03-2018, 12:10 PM   #98
So, a 1 doesn't need to go back in the middle?
Terry
03-03-2018, 12:18 PM   #99
monochrome's Avatar
QuoteOriginally posted by TerryL Quote
Terry
Over time you will decide what works best for you. I only have Fine Sharpness +1 on Bright and Natural. The other settings are all default.
03-03-2018, 12:58 PM - 1 Like   #100
I advised going to +2 based on lab tests, and test reviews, indicating that sharpening level for the K-1's in-camera JPEG processor to be under-done (conservative), resulting in slightly soft images. Since +1 is default, advancing by one level seems logical. So that should work fine without being overdone. The sharpening level being optimized brings out good edge sharpness in subjects, and the Fine Sharpening brings out fine detail.
The old K10D was the same way, but its adjustment control was sadly ineffective. This control problem was fixed in all later models, so now we have a very good control system.
03-03-2018, 02:53 PM   #101
It was advised by quite a few members. I certainly appreciate your help.
Terry
03-04-2018, 07:07 AM   #102
Mike,
Does anything go in the middle? I think it may of had 1. Thank you.
Terry
03-04-2018, 05:54 PM   #103
Terry, it is beast to leave other categories as-is at least for now. The Portrait category is not set up to maximize sharpness, is one example, since that might not serve portraiture very well.. As to the the other adjustments in the "Bright" and "Natural" categories, they are fine left as they are.
03-04-2018, 11:38 PM   #104
Mike,
Terry
What you are showing us in your two photos of your camera settings above is exactly right, exactly the best settings for Bright and for Natural categories. Again, having your camera set on the Bright category is best for almost everything.
Now that you've got your settings optimized, you can just go looking for good photographic opportunities and shoot some photos!
03-06-2018, 12:05 PM   #105
Great. Thanks for everything.
Terry
camera, center, change, f/1.8, fa limited lenses, focus, irix, lenses, look, manual, matrix, menu, multi-segment, nikon, pentax help, photo, photography, pm, post, school, sky, spot, subject, terry, tomorrow, troubleshooting
New K-lenses from Meyer Optik Görlitz : who tested ? Gedeon Pentax SLR Lens Discussion 14 01-03-2018 03:12 AM
"Thirteen" 50mm lenses comparatively tested on my new Pentax K1 camera Fenwoodian Pentax K-1 43 06-24-2016 07:52 AM
K-1 tested with FA Limited's HopelessTogger Pentax K-1 19 04-10-2016 07:59 PM
A number of Pentax lenses tested on FF sensor. sunCrm Pentax Full Frame 18 04-01-2016 05:31 AM
Tested K-5 w/ my current lenses. Next steps.. jaywes Pentax SLR Lens Discussion 7 07-24-2013 01:41 PM
All times are GMT -7. The time now is 05:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
