Originally posted by AggieDad
set my camera up 65 feet away on the tripod. I used mirror up and reset the the lens focus to about 3 feet between every shot so the lens focused each time. All shake reduction (camera and lens) was off. Photos were taken at 500mm at f/6.3, 1/800th, ISO 200.
Was my original thinking valid? If so, would these results be normal (i.e. so many settings with so little difference)? If not, what would be a good test?
Just to add to the feedback:
If your test target was closer, youʻd see a bigger difference because of reduced depth of field, but ultimately, Iʻd put the test target at an average distance your subject is anticipated in your use of this lens. So if 65 feet is in that range, that makes sense.
Yes, SR off, wide open f/6.3, but 1/800" is slower then Iʻd want to do tests with a 500mm lens. Iʻd try 1/1500" at ISO 400 to safely eliminate blur out of the results.
With ʻmirror upʻ were you AF with live view or your OVF? With live view, AF Fine tuning is not needed. With your OVF, you should be seeing a difference. If you canʻt see a difference between your -10, N, and +10, then that tells me either you were in live view, or your test target doesnʻt have enough detail to show and test the differences.
Instead of the license plate, can you tape printed matter to a fence and prop a yard or meter stick (or a PVC pipe or broom handle with incremental marks in front and behind the plane of the fence) at a 45 degree angle from the sensor/film plane?
And of course, it is possible your AF fine tune needs no correction with this lens, but there is a flaw in your testing method if you see no difference between -10 and +10.
