I have jury rigged a solution to the problem of the uni loop and possible rough/sharp split rings
it appears it would work with existing Op/tech USA equipment but I am using what I have on hand
the UltraFit Hand Strap with UltraPlate
Camera Hand Strap | Ultra Fit Hand Strap With Ultra Plate
and Joby Camera Safety Tether
Camera Safety tether for backup protection
I take the string section of the tether and feed it between the plastic female quick release and the strap and then feed the attached d ring through the loop
I attach the d ring (
metal ) to the metal split ring
I attach the uni loop male attachment not to the split ring but the attached hand grip
result, hand grip is tight to camera, sling via uni loop connected to hand grip and tether connected to camera and sling
best thing about this is that it is set up the back ups and forget
all safety systems are a go
only draw back is I cannot quickly detach sling, and must remove d ring from split ring to do so
____________________
similar to CSA set up but she has leather inserted into split ring in Post # 10
________________________
still undetermined should the lens support system be used with the large lenses as suggested by pete-tarmigan in post # 16
