Originally posted by pete-tarmigan . . . Sandy Handcock's, post reminded me that, on the K-3, the Uni-Loop Connector is threaded through those triangular split rings, which are in turn attached to lugs on the body. I believe, as Sandy wrote, that the sharp edges on the ends of the wire of the triangular split ring are what severed the Uni-Loop Connector. I have seen those sharp ends badly fray 3/8'' wide webbing straps.
I think you and Sandy are probably correct
in my opinion, Opt/tech USA which directs you to use the device in the manner that makes it vulnerable for such potential damage need to change their directions or warn customers to be aware of that and suggests ways to avoid the problem
as I said, I am in touch with their customer service rep and I will bring this to their attention on Monday
---------- Post added 03-09-18 at 19:34 ----------
Originally posted by jddwoods I agree with trying the rubber jar opener on the filter. That may just work, especially if you apply even pressure all around the filter ring. I do not like the fabric loop connectors on the triangular strap lugs. They seem more fragile than a full 3/8 inch strap would be. Years ago I bought a pair of them from op tech so I could try having both a shoulder strap and the pentax hand strap on my K-3. One of the fabric loops looked like it was starting to fray, so I gave up on the idea and went to just a shoulder strap. Sorry about the break and fall. I hope everything turns out to be in good working order. The filter and hood can be replaced, I hope the lens and camera survived the fall OK.
I was able to get the filter off:
another attempt at removing the filter was successful
4 years of high school wrestling and playing offensive and defensive line
I still have strong hands
[ strike reference to offensive line, of course, I never used my hands when playing that position
Read more at:
I have another boo boo, WARNING and seeking help - PentaxForums.com
the hood did suffer damage and I will most likely have to replace it
the damage to the filter I could care less
the lens and K 3 seem to be ok
and far as the other scratches - well it still looks better than my 2002 Suburban with 190 K miles, rust, dirt, grime and " bruises "
I can live with the cosmetic reminders
