Originally posted by neokind It took me a while, but after more than a year of using my K3ii, or a little more than a year ago, I realized that a lot of my shallow DOF pics were back focused. So, I did some googling, bought a lens calibrating scale, and tried to dial in each lens. The problem was, that even at +10, they were still focusing at -3cm on the scale I used. And this wasn't one particular lens, it was all of them. Frustrated, I started to just manually focus more. Now, I've been shooting a lot more and the backfocusing has been more of a nuisance. I pulled out the scale again, did some more reading, saw that someone suggested a global +10. I did it. Still back focusing. Somehow, though, I'd missed a step that suggested shutting off shake reduction. Suddenly, my lenses were dead on at a global +10. That's sort of good, I guess. But what's the deal? It's really frustrating, and I'm well out of warranty so it's not like there's an inexpensive solution. Are there other things I should consider doing? I'd like to use BOTH AF and SR simultaneously. Sheesh. I'd love suggestions.
Hi all,
Follow these guidelines, last summer I calibrated some lenses and the correct procedure is this one. (regardless of the calibrator brand in this case I used SpyderLens Cal)
1. Set up
Position the SpyderLENSCAL as shown below, with the main target vertical and ruler “0” mark aligned with the center cross-section of the target.
Make sure the SpyderLENSCAL is level by placing it on a flat surface, mounting it on a tripod or on a light stand with a bubble indicator.
2. Next,
Set up your camera and lenses by enabling autofocus,
turn off the stabilizing function (for Pentax, Shake Reduction), set the aperture to the largest f-stop (
lowest number) on the lens with the lowest native ISO setting.
If you are calibrating a zoom lens, set it to its longest focal length. 3. Make sure your camera and SpyderLENSCAL are
25-50 times the focal length apart. They should always be at the same height, with your lens and the SpyderLENSCAL target parallel to your camera's sensor plane.
4. Take Photo
Aim your lens at the center of the board on the SpyderLENSCAL target. Use the center autofocus point and capture an image. Use the self-timer or a cable release so you do not introduce any vibration.
Do not use live view to focus and capture the image of the target)
5 – Evaluate and Adjust
View the image of your SpyderLENSCAL target on the camera screen or even on your computer’s monitor. Zoom in on the ruler to evaluate the point of sharpest focus.
If the sharp focused mark is not “0”, enter the autofocus correction menu on your camera (this can be found in your camera's manual) and select “adjust by lens”. When the mark of sharpest focus is above “0” your camera and lens are back focusing. You should adjust forward to make a correction. When the mark of sharpest focus is below “0” your camera and lens are front focusing. You should adjust backward to make a correction.
Note: The numbers on the SpyderLENSCAL ruler do not correlate to the numbers in the adjustment menu.
Final Step – Check and Repeat
De-focus your lens manually then repeat step 2 and 3 to check that you made the optimal adjustment(s). Repeat this process for each camera and lens combination until “0” is the sharpest point on the scale.
Note: It is recommended to recheck the settings annually, when the lenses have been used frequently, when they have been exposed to extreme temperatures, or anytime you believe your focus performance has changed.
Happy work ! ''Buon lavoro''
