03-15-2018, 01:15 AM   #1
Issues with SDM lenses
I've recently started having issues with SDM lenses on my K-3.
I have two lenses, the 50-135 and the Sigma 18-35.
The lenses occasionally just don't move when I half press the shutter, or press the AF button.
If I manually focus the lens sometimes it comes good, and starts to work again.
It seems like the lens isn't getting enough voltage and the motor can't over come the static friction. When it does move, it seems slower than it used to be.
If anything the Sigma lens seems faster / easier to get moving again.
Screw drive lenses work fine.
I've tried a number of batteries, and charged them fully, it doesn't seem to make any difference.
Any ideas?
Thanks.
03-15-2018, 01:30 AM   #2
Maybe cleaning the electrical contacts on body and lens will solve the problem?
03-15-2018, 01:31 AM   #3
Seeker of Knowledge
aslyfox's Avatar
I have never had any such problem ( knock on wood )
but I have heard about this
does this article describe what you are dealing with:
Pentax SDM Failure Survey Results - Articles and Tips | PentaxForums.com
be sure to reviews the comments to the article
03-15-2018, 01:47 AM   #4
pjv
Otis Memorial Pentaxian
pjv's Avatar
Hi alloneword, your DA* 50-135 is SDM, but your Sigma uses a different type of motor ( HSM ). As @nobody suggested, cleaning the contacts on both your camera and lenses would be a very good 1st step. Good luck.
03-15-2018, 01:51 AM   #5
Seeker of Knowledge
aslyfox's Avatar
other thoughts
SDM to Screwdrive Conversions - Page 13 - PentaxForums.com
How To: Convert SDM to ScrewDrive + Video - Page 8 - PentaxForums.com
03-15-2018, 02:26 AM   #6
HYS
Cleaning is the first step ... the second step is changing the SDM motor. The new series of SDM's are really good - just personal experience. If you feel the lens is not focusing well, go to the service.
03-15-2018, 02:41 AM   #7
BigMackCam's Avatar
As has been suggested already, clean the contacts on both the camera and lenses first. It's worth cleaning all of the contacts and the mount ring, but for SDM operation pay close attention to the two gold-coloured contacts just inside the mount ring.
Also check that the two camera contacts are protruding the same amount. If I remember correctly, they're sprung. It's possible - unlikely, but possible - that one or both of them is stuck.
Good luck
03-15-2018, 05:02 AM   #8
sdm in my 50-135 died instantly
sdm in 16-50 - in the beginning it was not focusing on some occasions, than it stopped working altogether.
sdm in 55 has been squeeking for many years, but still working ok
repair costs are little more than 200$ (4000kc) here in CR and it takes 2 weeks
03-15-2018, 05:44 AM   #9
UncleVanya's Avatar
The 50-135 can be converted to ScrewDrive, but you should verify that it isn't a problem with the body before you go to that effort. Does anyone have an sdm lens you can test with, or another body you can check the lenses on?
03-15-2018, 08:25 AM - 1 Like   #10
jatrax's Avatar
If both the Sigma 18-35 and the 50-135 are having issues that points more to an issue with the body or the contacts, not the lenses since only the Pentax lens is SDM. Of course it could be both but that is unlikely.
As others have noted a good cleaning of the contacts on both camera and lenses is the first step.
03-15-2018, 08:43 AM   #11
UncleVanya's Avatar
My reason for asking about lenses is that the Sigma 18-35 has a history of poor focus across multiple brands. I didn't know if this was contributing to the problem. The 50-135 has a reputation for SDM issues as well. Given this I'd love to know if this was confirmed to be a body or lens specific issue before trying to dive in and solve it.
03-15-2018, 09:06 AM   #12
jatrax's Avatar
Agree. it is entirely possible the Sigma is having it's own (unrelated) issues and the 50-135 is having an SDM issue. It's not a good situation for testing because both of the lenses in question have a reputation for problems. Just not the same problem. Having another (known good) SDM lens to test with would be a good idea. After the obligatory contact cleaning.
camera, issues, issues with sdm, lens, lenses, move, pentax help, photography, press, sdm, sigma, troubleshooting
Do we still have SDM issues? Lev Pentax DSLR Discussion 27 09-24-2017 06:36 PM
SDM issues, real or imagined Yoda boy Pentax SLR Lens Discussion 26 07-06-2017 06:36 PM
DA 1.4x AW AF Rear Converter and SDM issues pjv Troubleshooting and Beginner Help 4 01-08-2017 06:09 AM
Quality issues of the 16-50 2.8 SDM Problems solved? 16-50 an K5 Discontinued? Celles Troubleshooting and Beginner Help 20 10-08-2016 11:24 AM
645D, K-m2 and NEW LENSES DA*10-16/4 SDM, DA*20/2 SDM, DA*28/2 SDM ogl Pentax News and Rumors 165 08-11-2010 03:26 AM
All times are GMT -7. The time now is 07:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
