Originally posted by Kevin B123 I would make sure the subject to focus on has a good change in contrast and is beyond the minimum focal distance, and in reasonable light.
If you can't lock on in those conditions something is wrong. As mentioned change lenses and try again to rule the lens out.
Hi there - thanks for the suggestions and ideas. Yes, I was ensure that the subject has good contract and min focal distance. I have been using cameras for many years now so was able to do this basic bit of debugging. I finally managed to borrow another lens and that works just fine. This was a 35mm prime lens and it has no issue. If I go back to my 18-135mm then it still doesn't focus.
Has the lens gone bad? Anything else that I can do? The lens contact seem fairly clean.
