Originally posted by Skodadriver There is also a Bower adapter that I believe is often cheaper than the Kippon. If you have not already, check out the reviews of these adapters on Amazon, any problems will probably show in the customer reviews.
Brand names mean little in the land of 3rd-party adapters. Conventional wisdom is that they are sourced from a number of suppliers in bulk and "branded" by packaging alone by the various vendors (Bower, Dotline, Kipon, Photodiox, etc.).
Originally posted by jatrax Most of the time the cheaper knock-offs are fine, but quality control is hit or miss. Some are perfect, some nearly useless. They also have a spring that generally needs removed or the lens can get stuck on your camera.
A good rule of thumb with the third-party adapters is to assume that it
will (eventually, if not immediately) get stuck on the camera unless the retention spring is removed as a precaution. A second expectation is that machining will be an approximation of the genuine adapter, even best case. Mounting generally requires a firm movement until the adapter and/or camera mount gets worn in.
Originally posted by theofon For now my plan is to get a cheap to test the lens and if down the road i decide to buy another m42 ill buy the official.
That sounds reasonable, but do remove the retention spring. If the adapter gets stuck, chances are good that a Dremel tool will be required to get it out.
A few additional comments:
- The genuine Pentax adapter is designed to float loose a slight distance below the camera mount face. This is to allow true registration of the lens flange to the body flange. The adapter allows the lens to "snug up" against the flange as it is screwed on (or mounted as a unit with the adapter). Tension is maintained by the springs that load the body-side tangs.
- Third-party adapters are designed as snug fit with the adapter approximately flush with the body flange face with registration determined by the position of the lens when fully threaded to the adapter or contact with the mount flange, whichever comes first. Depending on adapter, this may result in inability to attain infinity focus.
- Third party adapters usually (always?) lack appropriate machining in the area of the retention spring. The result is failure to release as well as possible over-rotation in the mount. Over-rotation is not a significant problem for current K-mount bodies, but may effect meter function with most film bodies.
- If a third-party adapter is chosen, be sure to give it a proper cleaning with rag and/or canned air before putting it on your camera. Fine metal dust and shards adhering to the metal are not unusual. Likewise, inspect carefully for obvious rough machining in the tangs and screw threads that might damage the lens or body.
Good luck with your exploration of the world of M42 lenses. There is some fine glass out there.
(...speaking from personal experience regarding stuck (Bower) adapter...)
